Vapor Smoothing PLA March 25, 2014 09:18PM |
Re: Vapor Smoothing PLA March 25, 2014 10:14PM |
Re: Vapor Smoothing PLA March 26, 2014 03:45AM |
Re: Vapor Smoothing PLA March 26, 2014 09:10AM |
Re: Vapor Smoothing PLA March 26, 2014 10:44AM |
Re: Vapor Smoothing PLA March 26, 2014 04:09PM |
Re: Vapor Smoothing PLA March 26, 2014 05:19PM |
Re: Vapor Smoothing PLA March 27, 2014 12:08PM |
Re: Vapor Smoothing PLA March 27, 2014 05:15PM |
Re: Vapor Smoothing PLA March 28, 2014 09:08AM |
Re: Vapor Smoothing PLA March 28, 2014 06:49PM |
Re: Vapor Smoothing PLA March 29, 2014 05:33PM |
Re: Vapor Smoothing PLA April 01, 2014 12:19PM |
Re: Vapor Smoothing PLA April 06, 2014 04:50AM |
iquizzle
The MSDS for MEK is 1-3-0, while the MSDS for Ethyl Acetate is 2-4-0 according to wikipedia. Are you really sure it's safer? MSDS would suggest otherwise.
Re: Vapor Smoothing PLA June 24, 2014 02:46PM |
Re: Vapor Smoothing PLA August 03, 2014 03:00PM |
Re: Vapor Smoothing PLA August 03, 2014 03:40PM |
Re: Vapor Smoothing PLA August 03, 2014 06:00PM |
Re: Vapor Smoothing PLA August 03, 2014 07:11PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Vapor Smoothing PLA August 03, 2014 08:13PM |
Re: Vapor Smoothing PLA August 13, 2014 09:59AM |
Re: Vapor Smoothing PLA August 13, 2014 11:51AM |
Re: Vapor Smoothing PLA August 14, 2014 02:41PM |
Re: Vapor Smoothing PLA August 14, 2014 02:46PM |
BackEMF
Thanks for the reminder, I almost forgot to check.
I just took the sample out of the vinegar and the only thing that seems to have changed is the color. The color is a bit more vibrant.
The PLA feels a bit more flexible but it can also be messing with my mind a bit. So lets just say it doesn't really work for what I had in mind. Still I put the sample back in the vinegar and lets see if a few more days will make a difference, I doubt it but since it has been sitting there for 10 days already i might as well leave it 10 more and then make that the final result.
If anyone has other 'safe fluids' to test with then why not give it a try.
Far as I understood acetone only works for ABS but not for PLA
And to be clear i'm looking for a way to soften PLA to make it rubbery so that i can print gaskets from normal PLA and then sotfen it to make it flexible so excuse me if I caused any confusion on this thread about smoothing PLA.
Re: Vapor Smoothing PLA August 15, 2014 05:11PM |
Re: Vapor Smoothing PLA August 15, 2014 07:03PM |
Re: Vapor Smoothing PLA August 28, 2014 07:52PM |
Re: Vapor Smoothing PLA August 28, 2014 09:41PM |
Re: Vapor Smoothing PLA August 29, 2014 12:06PM |
Re: Vapor Smoothing PLA August 30, 2014 10:06PM |
