Scaling Problems - Blender/3DS Max to Slic3r to print
Posted by kfootball15
March 27, 2014 02:35PM
When I export my stl from max or blender, my file is miniscule and I have to scale it up tremendously to get it close to the exact dimensions.
At the moment I have worked out the proportional problem by scaling up prints anywhere from 2500 to 2800 times the size that it is imported as.,
Does anyone know the exact amount that a model must be scaled up in slic3r?
Thanks,
Jeff
Re: Scaling Problems - Blender/3DS Max to Slic3r to print
March 27, 2014 07:35PM
2500 times or 2500%?
If 2500%, it's probably an inch->mm scaling issue, where your STL's are exported in inches but Slic3r expects mm. In which case, the exact scaling you need is 2540%, or 25.4 times.
