Finding Home
Posted by Waynester
Finding Home
March 29, 2014 12:07PM
I'm almost there. I've just configured my board (RAMBo 1.2) and it's working well.
One problem I have is I can't figure out how to set the "Home" position.
All the motors respond to manual commands except 'Home"
If I manually put the bed and hotend where I want them, then turn on unit and load Repetier it says that all axis' are at "0" ..if I move 50 mm for instance to the right (X) and then hit X home it moves about 5 mm and says that this is now "0" location...each time I hit home X it does the same thing. The Y axis does the exact thing....The Z axis moves 5 mm approx ...Up instead of back down to where (0) used to be. I know it's just a couple of adjustment in the Configuration. H but I have no Idea how to do it.
Any help would be appreciated.
Thanks again.
W.
Re: Finding Home
March 29, 2014 01:18PM
Sounds like your endstops are not wired properly or are all triggered. Sending an M119 will reveal everything.....
