Fan overcools hot end
March 30, 2014 07:45AM
Hi guys! I have a problem.
I am using anUBIS hot end to print woth PLA, and it causes jams. To fix this I mounted a fan blowing on hot end, but it results in temperature failure. As long as fan turned on temp. will not rise more than 120C. Here is my setup:
I realised duct was blowing on the heater a little bit too, so I made a new version of duct, and while it is not printed I used some tin make airflow blow only on teflon - but temp is still failing. Ajusting PWM value in repetier is no use. Any help?
UPDATE: I figured it out, it was 24v heater, and I've been using it on 12v
Edited 1 time(s). Last edit at 03/30/2014 01:45PM by NeoTheFox.
Re: Fan overcools hot end
March 30, 2014 09:10AM
what electronics and firmware ? and how is it connected. you can control fan speed with most set ups
March 30, 2014 09:32AM
cat.farmer
Ramps-fd, Repetier. Fan connected as Extruder 1, and pin 10 selected as hot end cooler in firmware. It behaves strangely, however - while PWM set to 255 it will not spin. I opened issue on github.
A2
March 30, 2014 11:54AM
Looks like there is a recall on the Ubis Hot End.
-Trouble staying at temp?
-Thermistor not registering?
-Nozzle clogged?
Printrbot $10 Hot End Replacement Program
[printrbot.com]
March 30, 2014 12:45PM
A2
-Nozzle clogged?
[printrbot.com]
There is no truble staying at the temp while fan is off, it stays almost perfectly even with no PID regulation.
