Re: I am tired of thermistors and I think we all need to look for a better solution April 04, 2014 07:30PM |
vreihen
jzatopa
I would like to point out that the solution doesn't really need to be a thermocouple. If we could find an M3 threaded thermistor that operated up to 300C we would have an ideal solution. I just can't seem to find one.
Did you check eBay?
http://www.ebay.com/itm/Modular-Screw-on-M3-Stud-Thermistor-for-Reprap-Prusa-3D-Printer-Hot-End-Hotend-/221312429218?pt=LH_DefaultDomain_0&var=&hash=item33873faca2
Not currently in stock, but it appears to be nothing more than an M3 brass standoff with a thermistor attached with JB Weld or something similar.
If you can find a thermistor small enough, they even make M2 brass standoffs if you want to DIY your own:
http://www.ebay.com/itm/100-Pcs-Male-to-Female-Screw-Brass-Pillars-Standoff-Spacer-M2x3mmx6mm-/131106624103?pt=AU_B_I_Electrical_Test_Equipment&hash=item1e86905267
What size thread is the set screw on an E3D hotend?
How the extra mass and metal will impact the temperature measurement accuracy is the big question.....
Re: I am tired of thermistors and I think we all need to look for a better solution April 05, 2014 05:01AM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 08, 2014 05:41PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 08, 2014 07:21PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 08, 2014 09:32PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 09, 2014 12:04AM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 09, 2014 08:19PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 09, 2014 08:31PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 10, 2014 04:30PM |
Re: I am tired of thermistors and I think we all need to look for a better solution April 12, 2014 06:14AM |
Re: I am tired of thermistors and I think we all need to look for a better solution May 03, 2014 06:09PM |
Yep, there is interest from me at least!Quote
fr
I found thermistors quite unattractive as well and designed a small thermocouple amplifier board. It's based on an AD8495 thermocouple amplifier chip, which is not the cheapest option, but offers reasonabl accurate temperatures. However, it is still less expensive than the other popular thermocouple amplifier choices for Repraps. The board is mounted near the hotend, so the fragile thermocouple wires do not need to move around. To the firmware, it just looks like another analogue temperature sensor, so the only things that need to be adapted are the thermistor tables. Thermocouples are nice for high temperatures, they're also inexpensive and quite robust. Of course, they do not offer the extreme amount of accuracy that thermistors can offer. However, I don't think this is important for these applications. Is there an interest in the board files/BOM/etc.?
