Repeatable positional accuracy of z-axis April 03, 2014 02:15PM |
Re: Repeatable positional accuracy of z-axis April 03, 2014 04:31PM |
Re: Repeatable positional accuracy of z-axis April 03, 2014 07:01PM |
No, it's currently set to the nophead's default of 200*16/1. 200 steps per revolution, 1/16th microstepping, 1mm per revolution of the M6 threaded rod.Quote
3dkarma
Check your firmware for steps per mm on the Z axis. If this is not a whole number it may be the reason you're getting inconsistent results. Try the test again with a whole-number multiple of the steps per mm setting.
The couplers are printed as part of nophead's design. They are pairs of these that sandwich the threaded rod and motor shaft. The motor shaft currently is cushioned to allow for some alignment inaccuracies by tight fitting nylon tubing. I actually have some replacement lead screws, nuts, and real couplings coming from Misumi in the next day or two as part of their free $150 promo. I guess that could be it, but it seemed to repeatable. If it twist flexes in one way, why not the other? Or why does the problem seem linear the farther I travel the more it's off when it returns? I'd think a twisting flex issue would show the same error margin whether it traveled 10mm or 30mm.Quote
What type of Z-couplers do you use? If there is any twist-flex in these it would account for the issue.
Re: Repeatable positional accuracy of z-axis April 03, 2014 08:18PM |
Re: Repeatable positional accuracy of z-axis April 04, 2014 04:44PM |
Re: Repeatable positional accuracy of z-axis July 23, 2014 03:41PM |
Re: Repeatable positional accuracy of z-axis July 23, 2014 04:54PM |
Re: Repeatable positional accuracy of z-axis July 23, 2014 09:02PM |
Re: Repeatable positional accuracy of z-axis July 24, 2014 02:22PM |
