Larry_Pfeffer Wrote:
> Forrest,
> First off, please forgive me for not following
> your work on printable rack and pinion drive
> systems more closely. What software is needed to
> run your rack and gear scripts?
You need the open source, free Art of Illusion 3D modeling app. You dump the scripts in the...
C:\Program Files\ArtOfIllusion\Scripts\Tools
...folder and then access them through the scripts option on AoI.
> Have you made any measurement of the backlash, due
> to the rack/pinion themselves? (That is, the
> back/forth motion possible when the pinion is not
> permitted to rotate. I realize that this will
> also be a function of the slop in the linear
> slideways.) Backlash becomes very important for
> milling, something I think will become important
> for speeding up the building of large parts.
> (Extrude faster, using a larger extrusion orifice,
> and then mill off the blobs that ooze outside the
> desired profile, once per layer.)
Herringbone gears have very little backlash. The slight printing imperfections in the ones I've printed seem to indicate that there is zero backlash. I've not made formal measurements, mind. Because the gears are plastic, I would not recommend them for use if you are planning to do milling. CNC milling generates significant xy stresses which, I'd guess, makes printed plastic racks and gears problematic.
> My repStrap currently uses leadscrews, but your
> work really has me convinced that printable
> rack/pinion should replace bought threaded
> driverods for the machines I attempt to print. I
> also find it notably cool that the Herringbone
> gear pattern can be extruded, but would be quite
> difficult to make using a conventional mill -- or
> even a hobbing machine (at least the ones I've
> actually seen outside of books.)
yeah, additive printing can do things that are difficult or impossible with subtractive CNC milling. I have come to the conclusion that we've got to stop thinking of our printers as just a poor man's CNC machine and start finding design solutions that exploit their strengths.
Hell, there are no rules here - we're trying to accomplish something.
Opportunity is missed by most people because it is dressed in overalls and looks like work.
Thomas A. Edison
