New.... Some help on what to go with is appreciated April 08, 2014 12:05AM |
Re: New.... Some help on what to go with is appreciated April 09, 2014 10:58AM |
Re: New.... Some help on what to go with is appreciated April 09, 2014 04:03PM |
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: New.... Some help on what to go with is appreciated April 09, 2014 06:36PM |
Re: New.... Some help on what to go with is appreciated April 09, 2014 07:31PM |
Re: New.... Some help on what to go with is appreciated April 10, 2014 02:45PM |
Re: New.... Some help on what to go with is appreciated April 11, 2014 12:41AM |
vegasloki
The differences between a Blomker Mendelmax 1.5 and a Mendelmax 2.0 due are the Y axis design (though many MM1.5 upgrade to W rail) and the build envelope as well as the number of parts, type of parts and method of assembly. The MM2 is designed for manufacturing rather than DIY though it is still a moderately easy DIY build. A big driver of the cost are the cut frame plates on an MM2 compared to the printed parts on an MM1.5. I can cut several sets of MM2 parts in the time it takes to print a single set of MM1.5 parts. The cost is in the operation of the waterjet (or laser) but it's a much quicker process.
The Blomker kit uses generic bearings and smooth rods whereas the MTW kit uses motion parts from Igus and Misumi. The MTW MM2 uses TR10 lead screws compared to M8 threaded rod on the Blomker kit. The difference in the motion components and the cut parts alone is several hundred dollars. The bed on the MM2 is cut aluminum compared to MDF with the Blomker. The Blomker uses an MK2 heat bed and the MM2 uses a polyimide heat bed/spreader design.
The Blomker kit seems like a good deal for the money even coming from Malaysia (Fed Ex can get it here in a few days) but comparing the two kits isn't exactly an apples to apples comparison. While both kits share a common name there are some differences that make a direct comparison difficult as they are basically two different machines though both use aluminum extrusions.
