Dual Extruder, Un-Retract at end of print?
Posted by Komb'
April 11, 2014 09:21AM
I'm working on my first dual extruder machine... still...
Two things I'm woundering.
1. Is there a way to un-retract at the end of a print?
My Dual colour prints always end with one or the other extruder in a retracted position. This is a problem when starting a new print. Especially if I forget it happened and don't manually corect it.
2. Is there a way to have both extruders primed, like the parimiter does for the first head?
I can't find anything is Slic3r for it...
Thanks,
Re: Dual Extruder, Un-Retract at end of print?
April 11, 2014 01:07PM
You could use an ending gcode, I'm not sure how the extruders are distinguished in g-code but you could try something like this which would have both extruders move (and likely leave hanging strings).
G92 E0 0.0 //Sets Extruder 0 position to 0
G92 E1 0.0 //Sets Extruder 1 position to 0
G1 E0 10.0 F1.7 //Moves Extruder 0 10mm at 100mm/min
G1 E1 10.0 F1.7 //Moves Extruder 1 10mm at 100mm/min
I'm not positive right now that is how you call out each extruder, also not sure that the "10.0" correlates to linear movement on the extruder and the feed is 100/60 = 1.6667, that also may be incorrect depending on if feed is mm/s or mm/m.
You could also try
G1 E0 0.0 F1.7
G1 E1 0.0 F1.7
And if the position wasn't reset with a G92 after the retract, they should return to 0.
April 12, 2014 04:00PM
I tried the last one, as it looked more eligant, but it just paused.
April 13, 2014 11:40PM
The last one would only work if they weren't already at 0, you may also have to use a G90 before sending those codes to turn on absolute positioning if it was turned off.
