3 axis non planar toolpaths FDM printing, patent pending
Posted by A2
A2
April 13, 2014 01:29AM
I would think that this has been done before.
Maybe some one with the right skills can figure out a workaround.
[www.topolabs.com]
Topolabs web video 2 med rev2
[www.youtube.com]
Re: 3 axis non planar toolpaths FDM printing, patent pending
April 13, 2014 04:47AM
It's another slicing program right? One that implements the "bed leveling technique" in the actual printing g-code?
Time to get it built into Slic3r!
_______________________________________
Waitaki 3D Printer
April 13, 2014 04:55AM
waitaki
could do it as a post processor, then you could use not only with slic3r but cura and other slicer programs, as well as being usefull for certain cnc applications
-=( blog )=- -=( thingiverse )=- -=( 3Dindustries )=- -=( Aluhotend - mostly metal hotend)=--=( Facebook )=-
April 13, 2014 06:29AM
This is interesting...
its taken slicing from the 2d layer by layer to the 3d so that a curved surface can be printed as one layer over variable Z heights
Not sure how useful it is, but it is certainly interesting.
April 13, 2014 06:53AM
It's the quality of finish I found appealing although it's not relevant on flat surfaces.
Isn't Slic3r's "vase" option doing the same thing but only in the up direction?
Waitaki 3D Printer
April 13, 2014 08:59AM
waitaki
I don't think so. Slic3rs vase option makes one continuous line that builds the vase. This looks like it makes individual layer but they use x y and z instead of just x and y. So it essentially makes a smooth 3 dimensional surface.
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
April 13, 2014 10:47AM
Would be very limited by nozzle/heater block clearances.
April 13, 2014 01:23PM
Cura already has a plugin that prints in three dimensions [www.thingiverse.com]
April 13, 2014 01:44PM
Dirty Steve
This is true for a machine with 3 axis motion, but a machine with higher degrees of freedom would not be as limited. Might be interesting to try this with Sextupteron or a printer based on a Stewart-Gough platform like this one.
April 13, 2014 06:14PM
This would be an amazing feature if the user could specify it for specific surfaces. No need to use it everywhere.
I highly doubt that 5-6 axis 3d printers will ever take off. The advantages are far too small compared to the complexity and expense added.
April 14, 2014 06:22AM
Dust
How about adding a inkjet printhead? This will make full color 3d printing possible.
