Re: 3D Labtek April 13, 2014 01:12PM |
3D labtek
We print only ABS parts. No PLA!
Why?
Parts printed in ABS in terms of rigidity, are not different from those printed in PLA.
What really makes ABS better is the HEAT RESISTANCE of ABS and IT'S DURABILITY.
In terms of recyclability, ABS IS MORE WIDELY USED IN ALL CONSUMER PRODUCTS;
at the end of its life in a product it goes to recycling making new products. So if you are concerned about the environment,
you should definitely buy parts from ABS. Once the usefulness of the parts are done, it gets recycle. Plastic goes in an endless recycling loop.
PLA is made out of corn. Do you really want the majority of your parts be biodegradable or durable like ABS?
You may ask,
if ABS is soo good why do some people print in PLA?
The answer is simple,
PLA IS EASIER TO PRINT. Beginners like to use PLA.
| FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
| Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: 3D Labtek April 15, 2014 09:31AM |
