There is g-code to set the current point to any value. If you move the head to the edge of the bed, set the current position to a point not at the edge of the bed - then you can move the head further. This is a slightly risky technique though!
It would be better to set the limits further in Marlin, and then make sure your slicer is set to not exceed the normally printable area.
