What's the proper gcode to move outside print area ? (nozzle parking)
Posted by Andke
April 14, 2014 05:39AM
(Merlin firmware)
I'd like to add some gcode that goes "outside" the usually allowed working X axis, - so the head can be cleaned.
- or should I configure Merlin as if X-axis is extra long, longer than working area ?
Re: What's the proper gcode to move outside print area ? (nozzle parking)
April 14, 2014 09:40AM
There is g-code to set the current point to any value. If you move the head to the edge of the bed, set the current position to a point not at the edge of the bed - then you can move the head further. This is a slightly risky technique though!
It would be better to set the limits further in Marlin, and then make sure your slicer is set to not exceed the normally printable area.
April 14, 2014 09:43AM
Thanks.
