Questions and Topics from Club Members April 23, 2014 02:26PM |
Re: Questions and Topics from Club Members April 23, 2014 02:47PM |
Re: Questions and Topics from Club Members April 23, 2014 02:49PM |
Re: Questions and Topics from Club Members April 23, 2014 03:31PM |
.15mm and 1.25mm respectively. You're at a university? That's like 2nd grade math.Quote
UNF3D
What is the difference between the size in both hot ends and extruders? I.E. .35 mm j-head vs .50 mm and 1.75 mm filiment vs 3.0 mm.
Re: Questions and Topics from Club Members April 23, 2014 05:06PM |
Check it- As nozzle D rises so does speed, quality lowering; vice versa.Quote
cdru
As nozzle diameter goes up, extrusion speed goes down but resolution, detail, and finish go down.
More turning for the same distance=more control over flow. Filament diameter is pretty much the same as nozzle diameter, smaller is more control, larger is faster. But filament diameter is much less something to look out for in detail, namely with wade's gears/etc. I like 1.75mm filament because I like accuracy over speed. I mean, with how little the extruder motor has to work for filament distances using 3mm for speed is pointless since 1.75mm can easily keep up with the other mechanics of the printer.Quote
cdru
Filament diameter is personal preferenece mixed with printer capabilities. Smaller diameter filaments can make direct drive easier or allow for more compact extruders. At one time 3mm was cheaper than 1.75 but anymore they are usually close in price if not the same so I'm not sure how much that's a factor. Given the same gearing and drive mechansim diameter, smaller diameter requires faster turning of the motor to match the same output extrude volume. But smaller diameter also can give you more control over the flow and having a smaller volume melting zone in the hot end. Any more for most printers I think it's just a personal choice.
