Anyone measuring force required to remove completed items?
Posted by Sci
Sci
February 05, 2010 08:25PM
I'm just curious if anyone's measured how much lateral force is required to dislodge a printed item from the print bed?
I'm sure it's different for different materials, but I'm wondering if it's within the power of the Y-axis if a fence were added on the extruder. IE: On completion, move Y-axis to one side, lower head, move Y back across to knock object off with the extruder (and presumably off the table and out the bottom of Mendel).
Peter "Sci" Turpin
London, England
Provider of practical solutions.
(Sometimes stellifying Jupiter IS a practical solution)
Re: Anyone measuring force required to remove completed items?
February 05, 2010 09:06PM
I think you would need a moving fence that rotates around a horizontal pin, so when the object is pushed against it, the fence returns a lifting force to peel the object
Wooden Mendel
Teacup Firmware
February 06, 2010 03:09AM
With a rigid bed, large objects are too hard to pull off by hand. They need a knife under a corner to start them peeling. Smaller objects can be knocked off with a sharp tap from a hammer. I don't the y-axis would be able to knock objects off in general.
That is why I made a flexible bed for easy manual release and am working on film held down by vacuum for automatic release.
Edited 1 time(s). Last edit at 02/06/2010 04:02AM by nophead.
