How to disable servo movement between probing point ? May 15, 2014 12:30PM |
Re: How to disable servo movement between probing point ? May 15, 2014 06:06PM |
Re: How to disable servo movement between probing point ? May 18, 2014 11:43AM |
Re: How to disable servo movement between probing point ? May 19, 2014 10:32AM |
Re: How to disable servo movement between probing point ? May 19, 2014 04:40PM |
case 281: // M281 - M281 P RUN - Fonction Perso dual extruder - Met le servo en bonne position en fonction de l'extruder actif
int servo_index = -1;
int servo_position = 0;
if (code_seen('P'))
servo_index = code_value();
// ##################################################### Modif section ###################################
if (code_seen('RUN')) {
if (active_extruder != 1)
servo_position = 30;
goto out;
else if (active_extruder != 0)
servo_position = 0;
out:
if ((servo_index >= 0) && (servo_index < NUM_SERVOS)) {
#if defined (ENABLE_AUTO_BED_LEVELING) && (PROBE_SERVO_DEACTIVATION_DELAY > 0)
servos[servo_index].attach(0);
#endif
servos[servo_index].write(servo_position);
delay(PROBE_SERVO_DEACTIVATION_DELAY);
servos[servo_index].detach();
#endif
else {
SERIAL_ECHO_START;
SERIAL_ECHO("Servo ");
SERIAL_ECHO(servo_index);
SERIAL_ECHOLN(" out of range");
else if (servo_index >= 0) {
SERIAL_PROTOCOL(MSG_OK);
SERIAL_PROTOCOL(" Servo ");
SERIAL_PROTOCOL(servo_index);
SERIAL_PROTOCOL(": ");
SERIAL_PROTOCOL(servos[servo_index].read());
SERIAL_PROTOCOLLN("");
break;
#endif // NUM_SERVOS > 0
#if (LARGE_FLASH == true && ( BEEPER > 0 || defined(ULTRALCD) || defined(LCD_USE_I2C_BUZZER)))
