Flexidrive is Flex3Drive Early Birds May 17, 2014 09:41PM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 12:29AM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 05:18AM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 06:29AM |
Mutley3D
One example is to be able to remove one of the Z motors on Cartesian style machines by using a pair of worms on the end of a cross shaft underneath or on top of the machine connected to the Z screws, driven by one motor. Just a teaser to get your mind thinking about the possibilities.
Anonymous User
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 09:01AM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 05:09AM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:47AM |
Admin Registered: 13 years ago Posts: 3,096 |
radus
You made easy X carriage and get more speed on X.
But Y axis with heat bed remains heavy and poor quality on Y.
Re: Flexidrive is Flex3Drive Early Birds - shipping May 19, 2014 02:22PM |
Many thanks for all your support out there.|
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:30PM |
radus
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:32PM |
Ohmarinus
radus
The solution would be:
- ultralight heatbed without any height-settings available to keep materials used to a minimum
- autoleveling on hotend
Or....... put the Z-axis on the heatbed and make an Ultimaker kind of setup. I think the Ultimaker setup would be ideal for this Flex3Drive.
No need for Z levelling probes.
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:44PM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 03:31PM |
MrDoctorDIV
And where does one purchase this magical device?
Edit: mutley3d.com opens blank
Also, is it possible, within reasonable added cost, to get a longer one? Say 1100mm shaft?
. Many thanks
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 03:56PM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:02PM |
MrDoctorDIV
What's the response like? What's the delay between motor movement and end movement? Flexing compared to bowden?
chirp from the motor. Pleasant insofar as the sound almost confirms how nicely it is running.|
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:53PM |
I've got 1:1 direct drive and never had even a warm motor [I've got a heatsink and fan, though]. Retracts around 80-100mm/s at 3.2mm distance. But you answered my question. I'm definitely a future buyer.Quote
Mutley3D
we do often hear of the motors and stepper drivers getting very hot, print freezes due to overheating electronics and so on.
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 02:51PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 02:57PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 03:00PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 04:51PM |
Re: Flexidrive is Flex3Drive Early Birds May 21, 2014 09:35AM |
Re: Flexidrive is Flex3Drive Early Birds May 23, 2014 03:05PM |
Re: Flexidrive is Flex3Drive Early Birds May 24, 2014 05:02PM |
jkoljo
Nice and interesting design. What's the second moment of area for the drive shaft?
Re: Flexidrive is Flex3Drive Early Birds May 24, 2014 05:09PM |
MrDoctorDIV
Here's another question: What's the horizontal distance that can be reache? It's a 900mm shaft, but with how things move and collide I can't imagine you'd get a movement range of any more than 5-600mm. Of course, I have no idea how in/flexible it is.
Anonymous User
Re: Flexidrive is Flex3Drive Early Birds May 27, 2014 10:43AM |
Re: Flexidrive is Flex3Drive Early Birds May 27, 2014 01:33PM |
Re: Flexidrive is Flex3Drive Early Birds May 28, 2014 04:37AM |
Re: Flexidrive is Flex3Drive Early Birds May 28, 2014 03:43PM |
karabas
What is the exact weight?
Re: Flexidrive is Flex3Drive Early Birds May 29, 2014 05:33PM |
Re: Flexidrive is Flex3Drive Early Birds May 31, 2014 10:26AM |
karabas
Mutley3D
karabas
39.22grammes without hotend
Including flexible shaft?
Re: Flexidrive is Flex3Drive Early Birds May 31, 2014 04:07PM |
