Flexidrive is Flex3Drive Early Birds May 17, 2014 09:41PM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 12:29AM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 05:18AM |
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 06:29AM |
Mutley3D
One example is to be able to remove one of the Z motors on Cartesian style machines by using a pair of worms on the end of a cross shaft underneath or on top of the machine connected to the Z screws, driven by one motor. Just a teaser to get your mind thinking about the possibilities.
Anonymous User
Re: Flexidrive is Flex3Drive Early Birds May 18, 2014 09:01AM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 05:09AM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:47AM |
Admin Registered: 11 years ago Posts: 3,096 |
radus
You made easy X carriage and get more speed on X.
But Y axis with heat bed remains heavy and poor quality on Y.
Re: Flexidrive is Flex3Drive Early Birds - shipping May 19, 2014 02:22PM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:30PM |
radus
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:32PM |
Ohmarinus
radus
The solution would be:
- ultralight heatbed without any height-settings available to keep materials used to a minimum
- autoleveling on hotend
Or....... put the Z-axis on the heatbed and make an Ultimaker kind of setup. I think the Ultimaker setup would be ideal for this Flex3Drive.
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 02:44PM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 03:31PM |
MrDoctorDIV
And where does one purchase this magical device?
Edit: mutley3d.com opens blank
Also, is it possible, within reasonable added cost, to get a longer one? Say 1100mm shaft?
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 03:56PM |
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:02PM |
MrDoctorDIV
What's the response like? What's the delay between motor movement and end movement? Flexing compared to bowden?
Re: Flexidrive is Flex3Drive Early Birds May 19, 2014 06:53PM |
I've got 1:1 direct drive and never had even a warm motor [I've got a heatsink and fan, though]. Retracts around 80-100mm/s at 3.2mm distance. But you answered my question. I'm definitely a future buyer.Quote
Mutley3D
we do often hear of the motors and stepper drivers getting very hot, print freezes due to overheating electronics and so on.
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 02:51PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 02:57PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 03:00PM |
Re: Flexidrive is Flex3Drive Early Birds May 20, 2014 04:51PM |
Re: Flexidrive is Flex3Drive Early Birds May 21, 2014 09:35AM |
Re: Flexidrive is Flex3Drive Early Birds May 23, 2014 03:05PM |
Re: Flexidrive is Flex3Drive Early Birds May 24, 2014 05:02PM |
jkoljo
Nice and interesting design. What's the second moment of area for the drive shaft?
Re: Flexidrive is Flex3Drive Early Birds May 24, 2014 05:09PM |
MrDoctorDIV
Here's another question: What's the horizontal distance that can be reache? It's a 900mm shaft, but with how things move and collide I can't imagine you'd get a movement range of any more than 5-600mm. Of course, I have no idea how in/flexible it is.
Anonymous User
Re: Flexidrive is Flex3Drive Early Birds May 27, 2014 10:43AM |
Re: Flexidrive is Flex3Drive Early Birds May 27, 2014 01:33PM |
Re: Flexidrive is Flex3Drive Early Birds May 28, 2014 04:37AM |
Re: Flexidrive is Flex3Drive Early Birds May 28, 2014 03:43PM |
karabas
What is the exact weight?
Re: Flexidrive is Flex3Drive Early Birds May 29, 2014 05:33PM |
Re: Flexidrive is Flex3Drive Early Birds May 31, 2014 10:26AM |
karabas
Mutley3D
karabas
39.22grammes without hotend
Including flexible shaft?
Re: Flexidrive is Flex3Drive Early Birds May 31, 2014 04:07PM |
