Anonymous User
Re: Flexidrive is Flex3Drive Early Birds June 01, 2014 08:49AM |
Re: Flexidrive is Flex3Drive Early Birds June 02, 2014 10:40PM |
karabas
What is your retract settings?
If f.e. Torsional Deflection = 6(12) degrees per ft per lb and effective diameter of hobbed bolt = 8 mm and stepper max torque = 4.4kg/cm
for 900mm shaft and 40:1 reductor
we get about max 0.125 - 0.3 mm e-feed error.
I wonder if it is acceptable. It seems it's better than bowden.
Re: Flexidrive is Flex3Drive Early Birds June 03, 2014 05:07AM |
Re: Flexidrive is Flex3Drive Early Birds June 05, 2014 08:38AM |
Re: Flexidrive is Flex3Drive Early Birds June 05, 2014 10:49AM |
Re: Flexidrive is Flex3Drive Early Birds June 05, 2014 11:39AM |
Re: Flexidrive is Flex3Drive Early Birds June 05, 2014 01:39PM |
MrDoctorDIV
I would love to know as soon as you have a dual extrusion version, the only reason I don't have dual on my Solidoodle is weight and size.
Re: Flexidrive is Flex3Drive Early Birds June 05, 2014 01:44PM |
umdpru
what kind of cable is used to drive the mechanism? Is it a small flexible shaft like a dremel rotary shaft or a larger diameter hollow shaft? Does the filament go to the hot end through the shaft or separately?
Re: Flexidrive is Flex3Drive Early Birds June 13, 2014 08:04PM |
Re: Flexidrive is Flex3Drive Early Birds June 19, 2014 04:46PM |
Re: Flexidrive is Flex3Drive Early Birds June 21, 2014 01:38PM |
pyrophreek
I am working with a Kraken quad extruder on a Rostock Max, and was wondering if you had considered working with Sanjay over at E3D to adapt your design to match with the Kraken. One of the big disadvantage of the Kraken is the need for four bowden setups, but your product might be a way to overcome that.
Re: Flexidrive is Flex3Drive Early Birds June 21, 2014 03:50PM |
Mutley3D
A quad drive Flex3Drive for Kracken would be a great development and yet another serious groundbreaker. I would be most happy to discuss and explore technical matters with Sanjay. Would he? I am intending to fit an E3Dv6 to one of my machines to confirm its compatibility with the Flex3Drive.
Re: Flexidrive is Flex3Drive Early Birds June 21, 2014 10:31PM |
Re: Flexidrive is Flex3Drive Early Birds June 23, 2014 09:13AM |
vreihen
http://coherent-reprap.blogspot.co.uk/2014/02/introducing-coherent-extruder-4-color-2.html
While I'm sure that you can easily make this work with two Flex3Drive cables,I'm going to challenge you to make it work with one cable and a solenoid for switching cams.....
Re: Flexidrive is Flex3Drive Early Birds June 23, 2014 09:21AM |
Dejay
... and a board to switch between thermistors and heaters would be really great.
Re: Flexidrive is Flex3Drive Early Birds June 23, 2014 01:33PM |
crispy1
Hey Mutley, could we get a quick update on where you are with shipping the original beta kits out?
Re: Flexidrive is Flex3Drive Early Birds June 23, 2014 03:41PM |
vreihen
Mutley3D
Someone has already cut the motor count in half:
Re: Flexidrive is Flex3Drive Early Birds July 06, 2014 03:56PM |
Re: Flexidrive is Flex3Drive Early Birds July 07, 2014 06:52PM |
Re: Flexidrive is Flex3Drive Early Birds July 09, 2014 07:43AM |
Re: Flexidrive is Flex3Drive Early Birds July 09, 2014 09:17AM |
Re: Flexidrive is Flex3Drive Early Birds July 09, 2014 04:38PM |
Rob_l
@Mutley3D
So to clarify, all the units you have sold to date should be shipped out before the middle of next week?..
Are you sending emails to inform people that their units are on the way?..
cheers
Re: Flexidrive is Flex3Drive Early Birds July 20, 2014 07:24AM |
Re: Flexidrive is Flex3Drive Early Birds July 20, 2014 01:48PM |
Re: Flexidrive is Flex3Drive Early Birds July 20, 2014 02:45PM |
First step to successQuote
Mutley3D
I tried. I failed. Sorry to let all of you down
Re: Flexidrive is Flex3Drive Early Birds July 20, 2014 06:50PM |
Re: Flexidrive is Flex3Drive Early Birds July 21, 2014 03:09AM |
Re: Flexidrive is Flex3Drive Early Birds July 22, 2014 11:59AM |
Re: Flexidrive is Flex3Drive Early Birds August 08, 2014 01:47AM |
Re: Flexidrive is Flex3Drive Early Birds August 16, 2014 08:33AM |
