Re: Flexidrive is Flex3Drive Early Birds August 16, 2014 10:58AM |
Re: Flexidrive is Flex3Drive Early Birds August 16, 2014 08:55PM |
Re: Flexidrive is Flex3Drive Early Birds August 17, 2014 10:17PM |
Re: Flexidrive is Flex3Drive Early Birds August 18, 2014 12:49PM |
foehnsturm
Adapted to an (already modified) Ulitmaker original. This is the very first print:
[www.youtube.com]
Re: Flexidrive is Flex3Drive Early Birds August 18, 2014 01:17PM |
jzatopa
I received my flexidrive and just mounted it to my mm 1.5 today for testing and although I can get a good first layer I am having trouble after that. Before I go much further though I want to make sure I am using the correct settings.
E-steps - 1800
E-Jerk - 5
accell - 3000
retract - 3000
Re: Flexidrive is Flex3Drive Early Birds August 20, 2014 07:39PM |
Re: Flexidrive is Flex3Drive Early Birds August 23, 2014 12:52PM |
Re: Flexidrive is Flex3Drive Early Birds August 23, 2014 08:01PM |
gmh39
Could this be used for motion as well? My idea is to use a few of these to remotely drive a ballscrew in a large format printer.
Any reason why that wouldn't work.
Re: Flexidrive is Flex3Drive Early Birds August 27, 2014 12:05PM |
Re: Flexidrive is Flex3Drive Early Birds August 27, 2014 01:31PM |
Re: Flexidrive is Flex3Drive Early Birds August 27, 2014 06:41PM |
foehnsturm
printing a little faster (rev3 printhead with spring loaded arm), 150 mm/s @ 0.15mm, looks like there is still some room
[youtu.be]
Re: Flexidrive is Flex3Drive Early Birds August 28, 2014 11:31AM |
Re: Flexidrive is Flex3Drive Early Birds September 10, 2014 08:16PM |
Re: Flexidrive is Flex3Drive Early Birds September 11, 2014 04:23PM |
pyrophreek
I am working with a Kraken quad extruder on a Rostock Max, and was wondering if you had considered working with Sanjay over at E3D to adapt your design to match with the Kraken. One of the big disadvantage of the Kraken is the need for four bowden setups, but your product might be a way to overcome that.
Re: Flexidrive is Flex3Drive Early Birds September 17, 2014 05:52PM |
jzatopa
Well I have had this extruder working great with 3mm and decided to try 1.75mm. The first print went fine. The second print had some problems with jamming. The filament is wrapping around the hobed bolt piece (I know it's not a bolt but I don't know what to call it). Is there a way to prevent this? If not I think that the design might need a few tweaks.
Re: Flexidrive is Flex3Drive Early Birds September 28, 2014 11:13PM |
Re: Flexidrive is Flex3Drive Early Birds October 13, 2014 07:55PM |
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 03:14PM |
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 03:59PM |
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 05:28PM |
UkIan
So what's inside this thing? I saw OozNest are selling them, the bits at either end are printed, it's just what ever is in the middle that's mystical.
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 05:42PM |
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 06:26PM |
Re: Flexidrive is Flex3Drive Early Birds October 14, 2014 07:18PM |
Admin Registered: 11 years ago Posts: 3,096 |
Anonymous User
Re: Flexidrive is Flex3Drive Early Birds October 15, 2014 10:52AM |
Re: Flexidrive is Flex3Drive Early Birds October 15, 2014 09:21PM |
Re: Flexidrive is Flex3Drive Early Birds October 15, 2014 09:24PM |
ridgenj
Hi, I ordered a Flexdrive back in August and the delivery was going to take a while. Are the kits being shipped by now?
cheers
Luis
Re: Flexidrive is Flex3Drive Early Birds October 16, 2014 03:47AM |
Ohmarinus
It's good to see you keep going, despite the trouble you had previously. I understand you got help from someone, also good to see others are willing to support a good idea
Re: Flexidrive is Flex3Drive Early Birds October 16, 2014 04:12AM |
Re: Flexidrive is Flex3Drive Early Birds October 16, 2014 07:00AM |
Re: Flexidrive is Flex3Drive Early Birds October 18, 2014 02:35AM |
