Flexidrive is Flex3Drive Early Birds
Posted by Mutley3D
Re: Flexidrive is Flex3Drive Early Birds
October 20, 2014 03:31PM
Any updates on duel extrusion model?
Realizer- One who realizes dreams by making them a reality either by possibility or by completion. Also creating or renewing hopes of dreams.
"keep in mind, even the best printer can not print with the best filament if the user is the problem." -Ohmarinus
October 21, 2014 06:18AM
I'd quite like an extruders sub forum and a hotend sub forum. I know there are various extrusion type subforums, but they don't deal specifically with what most people are dealing with, which is extruding molten plastic. So I'd second a call for somewhere nice to put this.
October 21, 2014 11:58PM
Quick update as I am away for two days. Outstanding orders are all assembled, and will ship friday 99.999999% smiling smiley
MrDoctorDiv - Dual filament version is now on the drawing board and various "questions in my mind" about the approach to this are now being actively considered.
October 31, 2014 10:39AM
I've got one now, merci Ooznest, so if I get time I'm going to try setting it up as one half of a dual hot end set up. One with the flexidrive, one with a bowden driven by a Bulldog XL. Should be interesting smiling smiley
November 17, 2014 08:33PM
I was toying with the idea of an extruder driven by a flexible shaft back in late 2012, but was convinced hysteresis could prove a problem. I'm happy to see that there's a way to make it work. Does the design do anything to counter hysteresis?
November 19, 2014 05:26PM
zachnfine
Hi Zachnfine, A combination of correct shaft specification, ptfe tubing and support structure, high ratio gearing within the extruder head, and extremely short filament forcepath allow even the most flexible materials to be printed without any evident hysteresis
December 01, 2014 12:01AM
My Flexdrive arrived in excellent conditions. Trying to decided to mount it on my Mini Kossel ot Kossel 250 V. Anyhow need help with recommendation for a stepper motor and how to get my E3Dv6 on it.
Not good at designing in OpenScad or similar. Any advice is welcome
Cheers
Luis
January 18, 2015 10:53PM
Any headway in adapting the feed mechanism to the kossel effector?
February 07, 2015 04:45PM
Hi Jason,
I am interested in the direct drive for my ultimaker original+. On youtube I see you have one build on an ultimaker 2, is there a version available for the original+?
Regards,
February 13, 2015 01:06AM
OK so its been real busy at this end which has pulled me in many directions. Thankfully ive cleared a LOT of stuff and am now back on to core design work, so lets see what the next few days bring.
SuperSurfer, there is a way to get Flex3Drive onto your UMO - There are a couple of user designs on youmagine.com. It would be very easy to convert a standard Flex3Drive to a UMO - I also have a UMO variant in the pipeline (all based on same parts) so I guess the short answer is Yes! smiling smiley
Krizzap, without making promises, let me see how the next few days pan out - There is a reconfiguration of the design midway through to enable an effecitve kossel mini variant. The reconfiguration of parts was the hard part (done) now just have to complete the printed part designs - 80% done but as we know, the last 5% is often the hardest yard.
Firmly back in this saddle and some interesting things are a brewing.
February 13, 2015 11:36AM
Hi Jason,
I have seen this design: [www.youmagine.com] and: [www.youmagine.com]
Neither will fit my UMO+ because of different hot ends.
Can you please point me in the direction of a design that would fit the UMO+?
Are you supplying all components like worm gear and such?
Kind regards,
February 13, 2015 06:51PM
SuperSurfer,
I presume you are referring to the original UM hotend and associated parts?
I have completed UM2 version which is now in last stages of running extended print and retraction torture tests and looking very suweet. UM Original version is part of current design activities and is at advanced stage. This will be running in next few days using same core components.
February 14, 2015 03:13AM
Retract Torture Testing on Flex3Drive
and a time lapse video can be seen here
more development info on its way smiling smiley
March 01, 2015 02:48PM
Need Some Suggestion
Recently I install Flex3Drive on my Prusa I3 .
I have some difficulty fine tuning it , problem is the infill , made a couple of test with different step per mm , it doesn't seems to change a lot .
Accuracy of the model is there , first layers of the infill barely stick on the bottom layer .
Printer was set at slow , I tried different software for slicing , slicer , Cura , kisslicer, simplify3d. All had the same result with the 20 mm hollow box 20%infill.
My guess was under extrusion , here's some pic of my problem .
I remove the flex3drive for now to be able to print some part , I need a better fan duct , and some way to hold the fan a bit closer to the aluminum heat sink. This was my second guess ,bad cooling .
If you guys seen this kind of behaviour before , I would greatly appreciate any suggestion , solution .
Thanks .
Edited 1 time(s). Last edit at 03/01/2015 02:49PM by Mort-O-RaT.
open | download - image.jpg (440.5 KB)
March 03, 2015 06:49PM
Hi Mort-O-Rat
Sorry to hear your having an issue there. Definately something not correctly setup but easily resolved. There are a couple of things to check and consider, so some initial questions to help me help you smiling smiley
1. Is the hot end secure in its mounting.
2. Is it a new filament or have you printed with it before (as opposed to a new spool) - PLA or ABS (looks like PLA)
3. What filament diameter (3mm or 1.75) and what temp settings are used?
4. What esteps and microstepping are you running with - have you set them to 1750 esteps with 1/8 microstepping on 3mm filament?
5. What retraction settings are you running (acceleration, retract distance and retract speed)?
M
March 07, 2015 08:25PM
Hi Mutley3D
Thanks for your response , sorry if I could not reply earlier .
to answer your question
1) Yes hotend was secure real tight in its mounting
2) No , I have use this filament before , no problem before , Black ABS .
3) Filament diameter is 1.75mm printed at 230C hotend , 100C Heatbed.
4)Set the E-step at start 1700 to 2000 throughout a couple of print , 1/8 Microstepping on 1.75mm filament
5) retraction setting a: accel E10000 , b: Retract Distance 2mm c: retract speed 10mm/sec
Here's my start g-code
M92 E(1700-2000)
M201 X3000 Y3000 E10000
M203 X500 Y500 E1500
M204 S2000 T200
M205 X15 E1
Cura Speed
40 Print speed
40 infill
30 outher perimeter
35 inner perimeter
I made the purchase of an E3D-V6 hotend . 1,75mm which took care of my fan problem , also took the time to make a nice fan duct for the turbo cooling fan use for cooling the print . The new hotend give me really great result , it is very light , it also made me realize how bad the oem hotend quality was , which im pretty sure didn't help at all to achieve acceptable result .
Disassembling the Flex3Drive was almost a good thing , I found the 3mm nut bolt of the idler arm inside the top of the hotend cooling chamber , this is why I had such difficulty fitting the filament inside (argggg!! lol) . Back at the time I thought it as fall somewhere on the floor as usual , search for it for about an hour , gave up , took another m3 nut since I got plenty ! Mistake . Im also pretty sure this didn't help to achieve acceptable result .
Since I got a bit of time tonight and tomorrow I will put back to Flex3Drive with the addition of the E3D-V6 hotend back on the printed carriage especially made for the Prusa I3 , its a bit worn since i drill a bunch of hole to fit some fan and option for z auto level , but its still sturdy enough to make some tryout , I am in process of learning some cad software to be able to design some mod or adjustment when needed , slow process , lack of time . but eventually ill know. for now ill go with what i have .
Also Mutley3D suggested that my PFTE tube was inserted maybe too far inside Flex3Drive , I remember putting a lot of pressure before securing the lock screw for that tube , so I will release about 1 to 2 mm off that tube from the Flex3Drive . Also pretty sure that didn't help to achieve acceptable result .
For the next set of tryout , I will increase the speed a bit since the flex3drive perform better at regular or faster speed i believe .
Now simple question , how to make sure i am right on for the e-step (is the measuring filament before the extruder hotend , extruding X amount , check if difference is accurate , is a good method)
Also should I put 1/8 micro-stepping for 1.75mm filament since you precise 1/8 on 3mm filament ?
If all goes well Ill post some picture progress soon enough
Thanks for your help , Flex3Drive I can wait to make you work .
M-O-R. (first language =French , sorry about my poor written english hopefully it is understandablesmiling smiley
April 08, 2015 12:10PM
krizzap
Did not see a response to this, but I was wondering the same thing. I was thinking this might work well for adding multiple extruders for a delta.
April 09, 2015 02:21AM
Rogue Scholar
krizzap
Rogue Scholar, Hello Sir smiling smiley There is a Kossel Mini version available, I just havent had a chance to put it up on the website as yet. From what i understand it will also work with other "mini" delta variants although there maybe a need to adjust the "end effector radius" in firmware. A very small tweak for such a large gain smiling smiley
Someone is running and testing it at the moment, PM me to get involved with bonus smiling smiley
BTW BIG Shout out to Joem_ for his help and excellent CAD work on this whilst ive been tied up on another Flex related project for someone else. Thank you Joe smiling smiley
Edited 1 time(s). Last edit at 04/09/2015 02:31AM by Mutley3D.
April 09, 2015 02:28AM
Mort-O-RaT
Are you back from your winter hibernation yet? Set your retract acceleration from 10000 to 100 as a safe value and run a couple of test prints and report back the results, if it works then you can start to turn up your retract acceleration back up in increments of 50 or 100 to find a safe optimal value. Your retract speed and distance setting is ok so dont touch these for now. I suspect you are skipping steps on retract. Also use 1900-2000 for esteps when set to 1/8 microstepping.
Let me now how you get along
May 23, 2015 10:19AM
I ordered a Flex3Drive on mutley3d dot com few days ago, and I would like to know how long is it to get it shipped (I paid 10 days ago and I only received one thing so far, the Paypal payment mail ;-) ).
Other buyers, how long was it for you ?
Thanks,
Laurent
May 23, 2015 01:36PM
Laurent04FR
Thanks,
Laurent
Hi Laurent, your item will ship early next week. There is usually a 5-10 day lead time before shipping. At the moment its closer to 10 days due to other Flex3Drive activities going on behind the scenes winking smiley After this lead times will be shorter.
M
Edited 1 time(s). Last edit at 05/23/2015 01:37PM by Mutley3D.
May 24, 2015 07:59AM
Thanks, that's great ! By the same time, I should have received to my Volcano from E3D.
I read you advise not to use more than 1/8 for microstepping.
I planned to use an azteeg X5 I already have (32 bit cpu, DRV8825 onboard). Problem is I have to use 1/32 microstepping with this board.
Do you think I can try with 1/32 or it's useless so I have to go with another board ?
Regards,
Laurent
Edited 1 time(s). Last edit at 05/24/2015 09:00AM by Laurent04FR.
June 20, 2015 04:16PM
Has anyone gotten this to work on any sort of delta printer? I'm still itching to put one of these on my Kossel but I lack the CAD skill to properly integrate the base into an effector..
June 23, 2015 02:50PM
krizzap
Hi Krizzap,
Kossel Mini or Standard Kossel?
June 23, 2015 08:54PM
any updated or improvements to the design so far?
WWW.ZATOPA.COM - Your Place for high quality 3D Printing Filament and accessories
June 25, 2015 02:23AM
Mutley3D
krizzap
Hi Krizzap,
Kossel mini, with a regular traxxas joints. I was actually considering another option for when I eventually upgrade to an E3D v6, which would be to mount the majority of the hotend (i.e. heatsink) above the effector plate, with the nozzle protruding below. This would save a little build height while also making more room to mount a flexidrive unit, away from the diagonal rods.
June 27, 2015 10:53AM
krizzap
Mutley3D
krizzap
Hi Krizzap,
Krizzap,
Check this out for a Kossel Mini smiling smiley Now a completed design. The rest of the album can be seen here [imgur.com]
June 28, 2015 12:35AM
Mutley3D
Krizzap,
The finished part looks good, very compact (only the idler is a bit of a mistery), is great that you're making progress with the Delta compatibility.
It seems that right now there is no space for a probe but i'm sure that once the design will be available we'll be able to fit one in.
I'll probably order a Flex3Drive next week, just a few quick question:
1-When do you plan on releasing the stl file for the Delta? (right now i'll use the Flex3Drive on my i3 but i plan on building a delta really soon).
2-I Guess the internal components for the delta design are the same inside the regular block, so is just a matter of print the new part -> disassemble the old block -> install the internal components in the new one?
3-What kind of lead time (for EU region) can i expect in this period?
Congratulation and Keep up the good work!
Edited 1 time(s). Last edit at 06/28/2015 12:38AM by Nova.
July 05, 2015 02:53PM
Sir, this is simply fantastic!! I absolutely am exstatic to try this out, bowden setups have alwas given me a tough time and this is exactly what I needed. I guarantee you I'm getting this kit from you the day it's ready, no joke!
July 12, 2015 03:06AM
I think the Flex3drive is a great way to remove weight from the printhead. Great idea.
Edited 1 time(s). Last edit at 07/12/2015 01:39PM by Lykle.
