Re: Flexidrive is Flex3Drive Early Birds July 28, 2015 09:12AM |
Re: Flexidrive is Flex3Drive Early Birds July 28, 2015 12:04PM |
yenbadnosyt
i've got mine installed on a delta (boots industries v2.5) and working for the most part.. but that might be just dumb luck on my part. i'm working on getting my stepping correct and the proper retract acceleration and speed. i think my retraction is keeping me from getting great surface finish results.. but than again i'm also getting little micro-pauses within each layer that give me over extrusion bumps... i think its all tuning on my end... but some more examples from people's slic3r profiles might help me
also is there anything about my stepper itself that i need to keep in mind?
Re: Flexidrive is Flex3Drive Early Birds July 28, 2015 01:06PM |
Re: Flexidrive is Flex3Drive Early Birds July 29, 2015 03:16PM |
Re: Flexidrive is Flex3Drive Early Birds July 29, 2015 06:06PM |
Re: Flexidrive is Flex3Drive Early Birds August 24, 2015 04:21PM |
Re: Flexidrive is Flex3Drive Early Birds August 26, 2015 06:28PM |
Re: Flexidrive is Flex3Drive Early Birds August 27, 2015 11:51PM |
Re: Flexidrive is Flex3Drive Early Birds August 29, 2015 05:39PM |
Re: Flexidrive is Flex3Drive Early Birds September 04, 2015 01:23PM |
Re: Flexidrive is Flex3Drive Early Birds September 04, 2015 01:25PM |
Re: Flexidrive is Flex3Drive Early Birds September 07, 2015 03:55PM |
Re: Flexidrive is Flex3Drive Early Birds September 08, 2015 04:35AM |
, admittedly its not an ideal lubricant to apply but it is the most effective for the gears since you will only need to do it once during initial commission. A light teflon based lube will also work but re-application maybe required after a few hundred hours printing time. DO NOT use a lubricant that has ceramic additives.|
Re: Flexidrive is Flex3Drive Early Birds September 11, 2015 09:25PM |
Re: Flexidrive is Flex3Drive Early Birds September 23, 2015 06:41PM |
Re: Flexidrive is Flex3Drive Early Birds September 23, 2015 07:48PM |
. All affected orders will receive complimentary print surfaces with their shipment as a gesture to compensate for the unforeseen delays. My apologies to those affected.|
Re: Flexidrive is Flex3Drive Early Birds October 02, 2015 01:55PM |
Re: Flexidrive is Flex3Drive Early Birds October 03, 2015 03:27PM |
SleepyPrince
I am interested in incorperating the Flexidrive into my next Kossel.
However, I am planning to use balls and magnets for the arms (and end effector) and probably using a E3D or Pico Hot-end.
I am a bit confused on what is included in Flexidrive package and what I will need to design / purchase if the included parts don't fit my needs.
Re: Flexidrive is Flex3Drive Early Birds October 03, 2015 06:10PM |
Re: Flexidrive is Flex3Drive Early Birds October 03, 2015 07:12PM |
MechaBits
Whats the difference with the flex drive, and the other method of pushing the filament down the ptfe tube(bowden/wade?), doesnt the spinning flexishaft create forces that you dont want, effecting print?
Re: Flexidrive is Flex3Drive Early Birds October 03, 2015 07:53PM |
Re: Flexidrive is Flex3Drive Early Birds October 04, 2015 12:07AM |
Re: Flexidrive is Flex3Drive Early Birds October 20, 2015 06:51AM |
Re: Flexidrive is Flex3Drive Early Birds October 20, 2015 11:23AM |
Re: Flexidrive is Flex3Drive Early Birds October 22, 2015 01:21AM |
Re: Flexidrive is Flex3Drive Early Birds December 03, 2015 10:28PM |
Re: Flexidrive is Flex3Drive Early Birds December 03, 2015 10:43PM |
Re: Flexidrive is Flex3Drive Early Birds December 04, 2015 01:19AM |
Re: Flexidrive is Flex3Drive Early Birds December 04, 2015 04:43AM |
Admin Registered: 15 years ago Posts: 2,569 |
truthbetold
I posted expressing my negative opinion of the flex3drive and it was deleted. The flex3drive does not work as Mutley says, buyer beware
Re: Flexidrive is Flex3Drive Early Birds December 04, 2015 06:34AM |
