Re: Flexidrive is Flex3Drive Early Birds September 24, 2016 05:55AM |
Re: Flexidrive is Flex3Drive Early Birds October 17, 2016 11:22PM |
Re: Flexidrive is Flex3Drive Early Birds October 18, 2016 06:47AM |
Re: Flexidrive is Flex3Drive Early Birds October 18, 2016 10:53AM |
Re: Flexidrive is Flex3Drive Early Birds October 18, 2016 08:43PM |
Re: Flexidrive is Flex3Drive Early Birds October 18, 2016 10:12PM |
Re: Flexidrive is Flex3Drive Early Birds October 19, 2016 05:44AM |
Re: Flexidrive is Flex3Drive Early Birds October 20, 2016 06:22PM |
Re: Flexidrive is Flex3Drive Early Birds October 20, 2016 11:27PM |
Re: Flexidrive is Flex3Drive Early Birds October 20, 2016 11:41PM |
For your bed you could buy PEI (mine is a 0.8mm thick glued to the glass) which I have on my printer and you don't need anymore any spray, tape or glue to hold your printouts, the flexi3drive sales the building plate which I may buy as well because I need to replace mine after in the beginning I used a sharp blade to remove the stuff I printed out when the bed was still hot - patience is not in my name.
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 12:19AM |
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 03:43AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 08:43AM |
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 08:45AM |
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 09:18AM |
slanwar
I used 3M 468MP high temperature adhesive transfer tape, hard to use as hell, tried to use the entire sheet so would cover the PEI but end up cutting small strips.
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 09:49AM |
Re: Flexidrive is Flex3Drive Early Birds October 21, 2016 10:13AM |
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 12:24AM |
I have also included a couple of other images I thought worth sharing. This post should address a couple of questions I have had recently about retraction performance on the Flex3Drive, aswell as the request for Kossel Mini info.
) It is only a short clip but I will get a better clip in the coming days.
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 08:52AM |
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 09:20AM |
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 05:53PM |
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 07:06PM |
Re: Flexidrive is Flex3Drive Early Birds October 28, 2016 10:27PM |
Re: Flexidrive is Flex3Drive Early Birds October 29, 2016 10:18AM |
Re: Flexidrive is Flex3Drive Early Birds November 03, 2016 11:49AM |
Re: Flexidrive is Flex3Drive Early Birds November 03, 2016 11:53AM |
Re: Flexidrive is Flex3Drive Early Birds November 03, 2016 03:49PM |
Re: Flexidrive is Flex3Drive Early Birds November 17, 2016 11:57PM |
Re: Flexidrive is Flex3Drive Early Birds November 18, 2016 09:43AM |
