FFC extruder / x carriage connectors idea (Flexible flat cables) May 18, 2014 08:34PM |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) May 18, 2014 10:34PM |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) May 18, 2014 11:02PM |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) May 19, 2014 10:09AM |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) May 19, 2014 10:26AM |
Depending on what the size is of the wires, 4 may not be enough for your extruder heater. A standard 40 watt cartridge heater needs 3.3 amps @ 12V. 3 wires are needed with an IDC cable for both +12v and ground. Unless you use a large pitch FFC I doubt you'd be able to get away with just 2 wires each direction.Quote
andy-net
Hot End
4 x heater
2 x thermistor
Extruder Motor
4 x stepper
Auto Bed Level
2 x micro switch
3 x servo
Fan
2 x Fan
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) June 23, 2014 10:41PM |
I was worried that the cable might get hot but not at all, and its printing just as good as ever. |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) June 24, 2014 08:16AM |
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) July 01, 2014 01:27PM |
that's very creative! and a lot less expensive I'm sure!|
Re: FFC extruder / x carriage connectors idea (Flexible flat cables) July 01, 2014 09:50PM |
