Problem of Nema17 controller
May 24, 2014 11:36AM
Hello to all
I explain my problem, I started a gen 7 (1.5) with Marlin as firmware and during my testing Repetier when I am sending a command to move an axis, the other motors starts at the same time on same direction ..
I then left one Pololu with its motor, all connected to my "X" part command and when the test engine meets all control Repetier, I click to move X or Y or Z the engine responds ... Mistere firmware or motherboard faulty ..?
Thank you for your help
Marc
Re: Problem of Nema17 controller
May 25, 2014 07:35AM
When debugging it's always a good idea to send G-code directly.
For a Gen7 I always recommend to use Teacup first, because this is known to work well. Other firmwares are more feature-rich but also more complex and with less emphasis on physically sane motions.
May 26, 2014 06:39PM
Problem solved! It was a configuration error (the exmple file provided with Marlin encoded for DELTA and not a Cartesian printerwinking smiley)
Now X and Y is progressing well against by the Z motor is made ​​clack clack and go without ever turning back ..
Someone has an idea?
