Contraptor
February 14, 2010 08:59PM
Perhaps this is something that could have an extruder strapped to it for FDM:
[www.contraptor.org]
$300 gets you a multi-tool capable apparatus...
Kevin
Re: Contraptor
February 15, 2010 02:34AM
Especially when you consider that all of their example machines use the Arduino GCode interpreter - definitely.
Re: Contraptor
February 15, 2010 04:18AM
The Contraptor folk hang out here sometimes.
[dev.forums.reprap.org]
Re: Contraptor
February 15, 2010 10:11AM
I see it only has 2" in the z-axis though...which is rather limiting for FDM. Maybe they will offer different scaled versions in the future.
Re: Contraptor
February 15, 2010 01:05PM
Some RepRap folk (me + people who think it is fun) are making similar machines and also working on modular building systems.
[objects.reprap.org]
and
and
Re: Contraptor
February 15, 2010 01:16PM
I like eiffel...would be nice to see eiffel made with t-slot with linear motion handled by rack and pinion perhaps...
Re: Contraptor
February 15, 2010 03:30PM
I agree. Would you like to tack up a name and a verbal sketch here:
I'm trying to distinguish subvarieties of "Basic Box", and I think a T-Slot Box is important enough that it needs its own name.
Eventually we'll be making RBS/Beam with T-Slots + Holes. Forrest is very close with his columnar rails with built in slots, but I don't think he's designing in regularly spaced through-holes yet, so that he can bolt three together to form the corner of a [[Basic Box]] or use sheets of masonite or steel pegboard as a stiffening element. Or even Meccano/Contraptor angle. Which I call [[RBS/Angle]]. smiling smiley
-Sebastien, RepRap.org library gnome.
Remember, you're all RepRap developers (once you've joined the super-secret developer mailing list), and the wiki, RepRap.org, [reprap.org] is for everyone and everything! grinning smiley
Re: Contraptor
February 19, 2010 07:57PM
> pinion perhaps...
That sounds a lot like CubeSpawn: http://cubespawn.com
Except Cubespawn is conceived of from the beginning as a modular system, so they can be linked together to form production chains. The concept is quite general, it doesn't require T-slot although T-slot helps: it could be angle-bracket a la Contraptor, or GridBeam in wood or metal, as long as it interfaces with other Cubes correctly.
Re: Contraptor
February 19, 2010 11:04PM
This particular arrangement has only 2" Z travel, but 3" is easily achievable by moving the X stage 1" down. This wouldn't require any new parts.
More than 3" in Z is also achievable if you only want FDM - by mounting small Z stage on raised Y (vs current arrangement of Y on Z).
I actually intend to use the sped up version of the mini CNC (with multistart leadscrews) as a starting point for a Repstrap/milling hybrid. I'm thinking that 3" height should be sufficient for most parts - is this a bad assumption?
Vitaly
[contraptor.org]
Re: Contraptor
February 21, 2010 01:47AM
> pinion perhaps...
That sounds a lot like CubeSpawn: [cubespawn.com]
Step 1 is get eiffel and other "Basic Boxes" up on the wiki and built.
Step 2 is chaining them together, like {generic production lines}, including CubeSpawn's fascinating work. We may accidentally reinvent Cubespawn, and we'll carefully cite the stuff that inspires us during the development process.
E.g. pick-and-place to modded toaster oven via ball-and-chain conveyor belt, etc.
RBS is a modular system. Eiffel is just a suggested and maintained, well documented configuration.
