cheap-o end stop? May 28, 2014 01:15AM |
Re: cheap-o end stop? May 28, 2014 07:23AM |
Re: cheap-o end stop? May 28, 2014 09:26AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: cheap-o end stop? May 28, 2014 09:57AM |
Re: cheap-o end stop? May 28, 2014 10:43AM |
Re: cheap-o end stop? May 28, 2014 10:46AM |
Re: cheap-o end stop? May 28, 2014 11:00AM |
Re: cheap-o end stop? May 28, 2014 11:07AM |
Re: cheap-o end stop? May 28, 2014 11:08AM |
Re: cheap-o end stop? May 28, 2014 11:47AM |
cnc dick
In my mind there is only a couple things that could do that one is you are running them normally open and you have a bad wire so it doesn't get the signal. Second your acceleration rates are so low that when it's trying to decelerate it actually taking all the over travel out of the switch and bottoming out before the can stop
Re: cheap-o end stop? May 28, 2014 03:09PM |
Re: cheap-o end stop? May 28, 2014 03:47PM |
ElectroWomble
Do you know how they were destroyed in each case? Ie were they destroyed by to much mechanical force or too much electrical current (You should be running them from a low current point on your electronics so this should not happen). Micro switches are remarkably reliable in many industrial/domestic machines. You don't need to spend more money to solve this problem. (apart from the small price of some new micro switches :-) )
Re: cheap-o end stop? May 28, 2014 03:48PM |
Re: cheap-o end stop? May 28, 2014 03:50PM |
3D-ME
Assuming you are using mechanical endstops, you might want to make sure that the paddles on your endstops depress before your X-end reaches the end stop mount. I had the X-end push my end stop mount down a little every time until the X-end hit the end stop mount instead of the end stop paddle, causing the nozzle to crash into the bed. I just modified the end stop mount, and tightened it in place, and that solved my problem. Either that, or it sounds like you might have some faulty wiring on your end stop.
Personally, the only way I've destroyed end stops is with superglue... So I designed and printed myself a new one, and it has worked very nicely for dozens of prints. I posted it here on thingiverse: 3D-Printable Endstop.
Re: cheap-o end stop? May 29, 2014 07:24AM |
