CAUTION! Simplify3D / Reprappro Melzi Users -FIXED May 30, 2014 09:54AM |
Re: CAUTION! Simplify3D / Melzi Users May 30, 2014 10:19AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 10:43AM |
Re: CAUTION! Simplify3D / Melzi Users May 30, 2014 10:43AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 10:45AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 10:53AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 10:55AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 11:11AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 11:36AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users May 30, 2014 11:44AM |
Re: FIXED May 31, 2014 11:09AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED September 05, 2014 08:42AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED September 21, 2014 05:45AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED September 22, 2014 07:44PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED September 23, 2014 03:02AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED September 23, 2014 04:23PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 01, 2014 03:29PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 18, 2014 04:43PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 18, 2014 11:26PM |
AJET69
hi donandi,
were you able to resolve your connection issue with Simplify3d?
I have the exact same issue and can't find a solution for it.
I have a Mendel90, running Marlin 1.0.0 RC2
Simplify3D suggested I install Teensyduino 1.20 for a better USB support via Arduino (I 'm using 1.0.6).
So I have installed Teenyduino in my Arduino, recompiled and uploaded Marlin, power cycled the printer, but there was no change.
I receive the same error message as depicted in you image for S3D and can connect with all other programs, CURA, Repetier, Proterface, etc.
Maybe an indication:
In Repetier I have configured sound files in preferences.
When I press the connect button in Repetier it connects and does not display any errors, however, the error sound is executed twice.
Could be that all other programs are a bit more fault tolerant than S3D.
In any case it is frusterating considering I have paid for S3D and only the free programs connect.
BTW: I have the same issue from two different PC's
On PC-1, I have;
Windows 7 Home Premium, Service Pack 1
AMD Phenom II X4 955 Processor 3.20 GHz (64 Bit), 4 GB RAM
Nothing else connected to USB, other than Keyboard/mouse, and Mendel90 printer
It currently does nothing else but serve the 3D printer
On PC-2, I have;
AMD FX-8350 Eight-core-processor (64 Bit), 16 GB RAM
On the USB: Keyboard/mouse, webcam & various external drives
When running S3D I have no other 3D software up and connected to the printer.
However, I did try to see if the error message is different, and yes it is.
The error message is also different when the printer is not connected. So I believe the printer and PC see each other.
On PC-1 I have deactivated all background programs, including the firewall, with the same error message every time.
On PC-1 it is trying to connect on COM3.
On PC-2 it is trying to connect on COM6.
The following error message is reported on 250000, 230400 & 115200;
"Attempting connection at \\.\COM3... (or COM6 on PC-2)
Testing plaintext communication protocol...
Testing binary communication protocol...
Attempting RTS reset and trying again...
Connection failed."
The slower speeds have an additional message containing;
“WARNING: framing error detected by hardware. Please verify that you are using the correct baud rate.”
Have both PC’s report the same condition would point to the printer.
However, the rest of the world’s 3D software connect immediately, which points back to S3D.
But then hearing error tones from Repetier during a connection may indicate it's the printer.
I'm confused.....
Any help is highly appreciated.
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 19, 2014 03:08PM |
, but it did not help.|
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 19, 2014 03:58PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 20, 2014 02:56PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 20, 2014 03:06PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 03:52AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 04:00AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 09:20AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 09:25AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 11:29AM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 02:32PM |
Re: CAUTION! Simplify3D / Reprappro Melzi Users -FIXED October 21, 2014 02:57PM |
