arduino ide
Posted by Anonymous User
Anonymous User
arduino ide
May 31, 2014 02:35PM
hi there does anyone have a base setup for arduino ide. i have lcd and sd hotbed and 5 end stops to configure into the ide but not sure if there is a base one i can dowload and modify or just start from scratch
Re: arduino ide
May 31, 2014 03:18PM
If you plan to write your own firmware from scratch, I encourage you to look at Marlin or Repetier firmware for a starting point.
If you are not a programmer and using a common electronics setup like the RAMPS/Mega2560, Repetier firmware has a menu-driven web configuration tool that does a lot of the work for you: http://www.repetier.com/firmware/v091/ . Just open up the resultant download package in the Arduino IDE and flash it to your board.....
