Sending g-code to smart LCD SD June 02, 2014 10:48PM |
Re: Sending g-code to smart LCD SD June 02, 2014 11:05PM |
Re: Sending g-code to smart LCD SD June 03, 2014 12:08AM |
Re: Sending g-code to smart LCD SD June 03, 2014 07:43AM |
Re: Sending g-code to smart LCD SD June 03, 2014 07:22PM |
tjb1
You're probably going to find that it takes forever to upload a file of any size and go back to using the computer to do it.
Re: Sending g-code to smart LCD SD June 04, 2014 03:19AM |
Re: Sending g-code to smart LCD SD June 04, 2014 06:06AM |
Re: Sending g-code to smart LCD SD June 04, 2014 09:26AM |
chris33
yes but some people might not have a reader so only option is that way
Re: Sending g-code to smart LCD SD June 04, 2014 09:32AM |
Re: Sending g-code to smart LCD SD June 04, 2014 11:29AM |
Re: Sending g-code to smart LCD SD June 04, 2014 06:29PM |
Antslake
I am already plugged into the ramps board. But taking 30mins to upload a file is silly too. With all this technology you think a better way would have been incorporated.
Re: Sending g-code to smart LCD SD June 05, 2014 01:00PM |
vreihen
Antslake
As I wrote above:
http://forums.reprap.org/read.php?1,364287,364763#msg-364763
"It does bear mentioning that Smoothieboard and the Azteeg X5 both present the on-board SD card slot as a thumb drive over the USB cable, in addition to having the serial link on the same cable. This setup does not suffer from the transfer speed problem that other firmware does."
You will appreciate the beauty of this setup when you're in Cura slicing an object, and simply click on the "Save to SD" button to write the file directly to the SD card in the printer at full USB speeds without any card juggling.....
