Makerbots can make Mendels, right?
Posted by Benbo231
Benbo231
February 20, 2010 02:25PM
What is the biggest part on a Mendel? Can a Makerbot print the biggest part? Anyone got any experience with making repraps by Makerbot?
If it is possible to make Mendels by Makerbot, there seems to be a fair amount of interest in them, and I will produce Mendel Printed parts, all day every day. I will then sell them.
Anyone willing to lend a newb a hand?
Re: Makerbots can make Mendels, right?
February 20, 2010 03:27PM
The X carriage (upper and lower) is the largest single parts of Mendel. It's ruffly 98 mm by 60 mm (so big you can't print it with a raft on Makrbot). That's part of the reason that warping is such an issue.
As far as "produceing them all day every day", be prepared to spend that much time for a week to produce just 1 set. Print time on a Mendel for a Makerbot is around 60-70 hours (that's just printing, no finishing, or raft). The few mendel sets that have been sold went for $300-$350 dollars for the full set. That means the world is willing to pay you $5 an hour to print Mendel parts with you covering plastic, electricity, and machine costs.
The positive side of the argument is The world is willing to trade you
1.5 Mendel sets = Catalyst by Profounddevices (if it works)
2.5 Mendel sets = A Makerbot Cupcake
3.5 Mendel sets = A BfB Rapman
Edited 1 time(s). Last edit at 02/20/2010 03:29PM by spacexula.
repraplogphase.blogspot.com
Benbo
Whatchoo talkin 'bout?
February 20, 2010 08:36PM
The trading, what are you talking about?
Re: Whatchoo talkin 'bout?
February 20, 2010 08:58PM
What I am talking about is that basically if your printed a set of Mendel parts, you could reasonably expect to get around $300 for the set.
Rapman costs 1200, Makerbot 750, profounddevices has now went to 500.
Benbo
February 20, 2010 09:06PM
...oh...Do you think it would be possible to print the mendel thing in parts, then bolt it together?
February 20, 2010 09:45PM
.... you do realize that these are PARTS for Mendel right? Smallest parts are 2mmx2mmx4mm, largest part is 96x60x20mm.
Benbo231
February 20, 2010 11:07PM
Yeah, yeah. I meant, print the too big parts in chunks that are the right size, then bolt them together. Is that possible, or ?
February 20, 2010 11:53PM
I have not seen anyone do that. The way I printed them was to print other Mendel pieces VERY close to the parts that tend to warp. I printed my x carriage with z bar top clamps on both sides, and belt clamps in the middle. No warping issues when I did it that way.
Benbo
February 21, 2010 08:23AM
So you're saying that makerbots CAN NOT make mendels without a lot of fuss and bother, I'd be better off buying a BFB Rapman to start? I have the cash to get both...
February 21, 2010 10:21AM
"fuss and bother" is relative. It does take 60-80 hours to print Mendel + another further 40+ hours to put it together and calibrate. You would then be putting together something that less than 2 dozen other people have put together in the world, so you would be at the crest of the wave.
It you have the money, I think it's best to start with either a Makerbot or Rapman. Then build a Mendel. If you just want it to be easy, then just keep buying the kits.
The kits are easier to put together, and have had more of the grimlins worked out.
benbo
February 21, 2010 12:16PM
In that case, I'll start with a Rapman. Rapman gets bigger print zone, but less plastic to start with. So it's a bit more expensive for a lot more capability. Thanks for your input, it was a huge help Spacexula.
February 21, 2010 04:29PM
My opinion is Makerbot is the better choice of kit (I am bias, I own one).
-750 vs 1100, almost half the price.
-Equal or slightly higher print speed
-MUCH more dynamic community
-More venders sell parts for makerbot
-Makerbot is completely open source, Rapman is only partial open source
-Multiple commercial heated build plat options
-Modular boards allows you to replace motor driver, and extruder board without replacing mother board.
Rapman is slightly more accurate than makerbot, and has a on bot interface (can print without an attached computer.
If you have the money for a Rapman, just buy two Makerbots.
Benbo
February 21, 2010 05:04PM
If a Rapman is a commercialized reprap, I can upgrade to a Mendel. Not to mention I need the $950 kit if anything, the $750 doesn't have enough plastic to print all the mendel parts I would sell. and no cable, power supply, etc. which leaves me with a $150 difference for a much bigger print bed, but 4 lbs less plastic. I hope to get a makerbot to help with mendel production after I print 3 sets of mendels.
February 21, 2010 07:34PM
I don't have the post, but one makerbot user redesigned the biggest part to be printed into two sections and then glued together.
benbo
February 21, 2010 08:24PM
Well...I'd still like the larger print bed. It will come in handy later on anyways...
February 21, 2010 09:05PM
I printed the X carriage on my MakerBot. The key is to either use PLA or a heated build platform if you use ABS. Either way, a raft isn't needed.
Todd
February 21, 2010 09:19PM
Just saying, lonely road for Rapman in the US.
Good luck finding parts without paying VAT, and $30 shipping.
benbo`
February 21, 2010 09:47PM
Vat?
February 21, 2010 09:54PM
Value Added Tax. 17% for england. I think you have to pay it on the Rapman. (might be wrong, you might want to check)
[www.bitsfrombytes.com]
Yep, you have to pay the VAT, they don't include it in the price.
VAT, + Shipping. That's going to be fun.
Edited 1 time(s). Last edit at 02/21/2010 09:56PM by spacexula.
February 21, 2010 11:38PM
But isn't most of that sitting around letting the machine do all the work? If I can get be checking on it between tv shows, and just restarting when it screws up, that 60-70 hours is only what, 5 hours of actual work? (Just guessing on this number)
February 22, 2010 01:23AM
Yes and no.
You need to be around, because sometimes things just go wrong.
It usually take 10 minutes for a printer to warm up, 15-20 to skein forge the file, 5 minutes to load the file and get software ready, then you need to wait for the raft and 1st layer to print (part that is most likely to need tweeking). Then you are free till the print is over.
Now if you are going to print multiple parts you have to mod the g-code to keep your zero, and keep temp (or be prepared to rezero and rewarm). But if you do that, you can end up leaving your machine hot for an unhealthy amount of time (not that I have ever found my printer with a head that I left running for 8 hour unattended winking smiley
There is a profession that pays good money, it's called a CNC operator. There is a reason they get paid a good bit of money, even though "the machine does all the work".
Benbo231
February 22, 2010 11:08AM
vat = load of sunshine. Seeing as i'm in school most of the day, I start the bot as soon as I wake up, then leave for school. Chances are, The part will go smoothly, and I will return to see a part finished. Not that I'll ever need to skeinforge anything yet, I plan on using my printer to print already-done parts like mendel components.
February 22, 2010 12:19PM
It's a goal we'd all like to achieve, but most reprap-based printers are not "Set it and forget it" at this point. Once you get everything tweaked, that's a real possibility, but don't expect to do it right out of the box. This was the dream that I have as well. Right now my plans involve a live web feed and a remote kill switch. If something does go wrong, I can kill the part before the printer goes through another 10 feet of filament.
If you can do it, more power to you! The community certainly needs the parts...
February 22, 2010 01:24PM
Ultimately: you could make a full time job out of it given a sufficient number of machines. Computer vision may have an application here. A part should fit within a boundry which can be superimposed over the video feed, and the print head should move in a predictable manner: EG IR LED.
Benbo
Vision algorithym?
February 22, 2010 08:13PM
So, that's one of my other projects. But I've postponed that until I can finish assembling my rapman, pgrading to a mendel, and getting a few sets cranked out.
February 22, 2010 09:31PM
Likely the plastic bits for Mendel have a very high price elasticity.
We can only get $300 for them now, and there are NONE avaialbe. If some of us start printing these part time, the price is going to tank.
Remember the price ceiling is set my printer like maker bot.
If the few of us that like printing Mendel parts make a part time job of it, the price will likely floor at 100-200 dollars, or comparable to the cost of a laser cut alternative.
Now likely the 1st 100 printers will likely be sold at the $300 price point, and honestly can't wait to have this problem.
February 22, 2010 10:03PM
Even if the market for Mendel bits does tank, it'll still be more than the cost of the materials, which means if your printer is reliable enough that you don't have to put a lot of work into each print batch you can still make it pay for itself. I also think that there's definitely a market for prototypes made on mendels, darwins, and makerbots, and with the help of services like etsy and ponoko (and craigslist, for that matter) it'll be possible to earn money with a reprap for quite a while.
February 22, 2010 11:18PM
hi i want to buy a full set of mendel. are you selling it? how much are selling it? i am sincerely. but i also need to get the elecronic, firmware and mechanical design file. if you are selling it, can you let me know where is selling it? i would like get the comparable kit. i know makerbot and see it in action and it is pretty cool.
best regards
February 23, 2010 01:32AM
> quite a while.
Your time has value. Mendel at 300 is paying you $4 an hour at no compensation for power, filament, or wear and tear. With proper compensation for those 3 factors you will be paid $2 an hour at $300.
Printing Mendels for people at $300 is already a charity case, or labor of love. At $150 it's a fools errand.
February 23, 2010 02:13AM
> reliable
> a
> like
> matter)
> for
> > quite a while.
> $300.
> fools errand.
If you say so. Personally I've never seen any consistent figures on the average power consumption of a printer, MTBF for any of the extruder designs currently in use, etc. You also have to consider whether you count all of the time the printer is running as "your time". Depending on your individual situation, that might not be the case. If I were hiring someone to run a machine for me, I would consider that the case. If I'm running it on weekends while I watch TV or work on something nearby, the cost to me is significantly lower than the total time would indicate. The big thing to consider is that with the exception of setup, removal, cleaning, and in the case of a failure repairs, there is little opportunity cost to running a 3d printer. Given a reliable extruder, you could in theory set up a print in the morning and go then go to work and get paid a full wage for your time. In that situation, unless you're being paid only cost for the parts (including repairs and feestock), you're losing money any time you're not printing mendel parts or other models.
And yes, I'm aware that time has value. Acutely so. That's why I've qualified all my statements with a mention to having a RELIABLE printer and extruder. If you have an unreliable setup, then the time you have to sink into repairing the machine makes it unprofitable. I've taken economics, I get it. But at $150, selling mendel pieces still sounds like a good way to pay for the feedstock you use on your own parts (I repeat, given a reliable printer requiring little to no maintenance). Unless you're going to tell me it takes more than 10lbs of ABS to build mendel?
