Printing Nylon Trimmer Line June 10, 2014 10:02AM |
Re: Printing Nylon Trimmer Line June 10, 2014 10:15AM |
Re: Printing Nylon Trimmer Line June 10, 2014 11:01AM |
Re: Printing Nylon Trimmer Line June 10, 2014 11:26AM |
Re: Printing Nylon Trimmer Line June 10, 2014 03:02PM |
Re: Printing Nylon Trimmer Line June 10, 2014 04:20PM |
Iceman086
I have used the Red version of this stuff. Same seller, same product, just a different color.
It works amazingly well but you have to bake it at 175F for about 3-4 hours to get all of the moisture out. It has a really nice surface finish to it that is very shiny and smooth.
When your not using it I would highly suggest putting it in a sealed container with desiccant packets to make sure that it doesn't absorb moisture again.
If you run it you will get a little bit of steam coming out of your nozzle and on my Ultimaker Original I had to run it at 235 and 60ish mm/s with a 135 flow rate. I made a few of the antivibration feet and they work great. If you make a stretchlet it will stretch beyond belief. Its some great stuff you just have to remember to bake it first and keep it sealed so it doesn't absorb water again. If you start to see alot of steam coming out of your nozzle then it needs to be baked again to get rid of moisture. The water effects print quality alot.
I
Re: Printing Nylon Trimmer Line June 11, 2014 01:20PM |
Re: Printing Nylon Trimmer Line June 11, 2014 11:41PM |
