Heated build chamber patent limitation June 11, 2014 02:52PM |
US7297304 B2
Existing Stratasys FDM® machines build models in a chamber (also referred to as a build envelope or oven) heated to between 70° C. and 90° C. The base on which the model is built is located in the heated chamber, as are the extrusion head and the x-y-z gantry. Placing the extrusion head and the x-y-z gantry in this heated environment has many disadvantages. The x-y-z gantry is comprised of motion control components, such as motors, bearings, guide rods, belts and cables. Placing these motion control components inside the heated chamber minimizes the life of these components.
Re: Heated build chamber patent limitation June 11, 2014 03:28PM |
Re: Heated build chamber patent limitation June 11, 2014 04:39PM |
Re: Heated build chamber patent limitation June 11, 2014 10:57PM |
Re: Heated build chamber patent limitation June 17, 2014 11:01AM |
Re: Heated build chamber patent limitation June 17, 2014 11:38AM |
Patent infringement doesn't just apply to the sale of items.Quote
akhlut
There is nothing preventing you from constructing your own heated chamber.
Re: Heated build chamber patent limitation June 17, 2014 11:54AM |
mkelly
akhlut
There's nothing preventing you from doing it, but you could theoretically be sued for it. Not saying it would ever happen, but they have that option.
Re: Heated build chamber patent limitation June 17, 2014 12:45PM |
Re: Heated build chamber patent limitation June 24, 2014 10:45AM |
Re: Heated build chamber patent limitation June 24, 2014 01:05PM |
Re: Heated build chamber patent limitation June 24, 2014 01:08PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: Heated build chamber patent limitation June 24, 2014 01:45PM |
