Re: Nema 17 - stronger motor alternative June 23, 2014 05:41PM |
Admin Registered: 18 years ago Posts: 14,170 |
Re: Nema 17 - stronger motor alternative June 23, 2014 09:54PM |
Arnold
Hi Jim,
I am thinking about at final 2x1,5m work area. I would like to cut just boards from wood, plastic, maybe aluminium. But firstly I want to make a little cnc for tests. Frame and linear rails will be aluminium, threated rods m8. Everything must be cheap so I dont plan to use some special components. I dont want to safe money on motors because I will sure make upgrade, so that is for future - I dont want to buy motors again. My idea for start is connect some strongs universal motors with arduino, but dunno how. I am total noob in electricity. Speed is now not so important but again, strong fast motors would be good for future upgrade. Spindle I would use some casual for wood at start, so no controling through pc. At the end I would like to choose special electronic for pure cnc working with mach3, but my vision for start is just testing with arduino.
Re: Nema 17 - stronger motor alternative June 24, 2014 10:25AM |
Jim Fong
I use the 276oz-in stepper from automation direct and gecko drives for my gantry router. Does 300ipm rapids. Stay away from the bigger 400oz-in steppers unless you can afford a higher voltage power supply and very good stepper drivers. The smaller 276oz-in can spin pretty fast, a big plus if you are using threaded rods.
Re: Nema 17 - stronger motor alternative June 24, 2014 03:00PM |
A2
Gantry Type Machine Building Lots of good info can be found here for routers.
[www.mycncuk.com]
Jim Fong
What voltage are you powering the 276 oz-in at, and how many amps are your drivers?
What difference, or gains would I see switching from 12v, to 24v? Does the torque increase, higher speeds, quicker acceleration?
I was looking for a ~400 oz-in motor, but based on your comment I'm now I'm unsure if that's what I should get. NOTE: I'm using 15 mm wide belt, with 4:1 pulleys, no screws. Worse case, I probably have about 12 lbf to move, so I'm looking for a motor that can move ~24 lbf.
Is it possible to use the $10.00 drivers that most RepRaps use? I've been looking at the ~$50.00 drivers, I welcome the savings if it's possible.
Automation Direct motor comparison:
[www.automationdirect.com]
Tks.
Re: Nema 17 - stronger motor alternative June 26, 2014 01:04AM |
