Comparisons - what speeds do you get? June 15, 2014 08:21AM |
Re: Comparisons - what speeds do you get? June 15, 2014 08:33AM |
Re: Comparisons - what speeds do you get? June 15, 2014 03:10PM |
Switchblade88
- Acceleration at 500 m/s (much smoother now it's lower than 9000m/s!!)
At 0.3mm layers, I can get 100m/s prints [...]
| Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Comparisons - what speeds do you get? June 15, 2014 08:01PM |
Traumflug
Can we assume you mean 500 mm/s2, 9000 mm/s2 and 100 mm/s?
Re: Comparisons - what speeds do you get? June 16, 2014 08:54AM |
Re: Comparisons - what speeds do you get? June 16, 2014 09:24AM |
Re: Comparisons - what speeds do you get? June 16, 2014 09:28AM |
Re: Comparisons - what speeds do you get? June 16, 2014 09:51AM |
MrDoctorDIV
Acceleration, while allowing higher speeds, lowers the quality of your corners.
Re: Comparisons - what speeds do you get? June 16, 2014 10:04AM |
Admin Registered: 13 years ago Posts: 1,063 |
Traumflug
MrDoctorDIV
Ah, it has taken RepRap how many years to recognize this simple fact of physics? Higher acceleration means higher forces and as such more printer frame bending. Not to mention a higher risk of step losses (which resulted in many people searching for position encoders / verification methods).
If you get better quality with higher acceleration anyways I'd guess it's due to the fact that extruders don't push out material immediately, but do so a bit delayed. On what "delayed" exactly means, experts debate for quite a while already.
Re: Comparisons - what speeds do you get? June 16, 2014 10:09AM |
thejollygrimreaper
Traumflug
MrDoctorDIV
the bottom line people seem to forget also is that we are building printers, not race cars
Re: Comparisons - what speeds do you get? June 16, 2014 05:54PM |
Re: Comparisons - what speeds do you get? June 17, 2014 12:10AM |
MrDoctorDIV
I used to have an acceleration of 1000m/s2, but have since raised to 4000m/s2 and a bit slower speed, vastly improving my quality.
