Auto square the gantry each time you home
Posted by A2
A2
June 16, 2014 01:34PM
Myth or reality?
Inductive proximity home/limit switches including dual ones to auto square the gantry each time you home.
[www.mycncuk.com]
Video of the router cutting
[www.youtube.com]
Re: Auto square the gantry each time you home
June 16, 2014 06:04PM
It is a very good idea if you are using two motors to drive a gantry, especially if microstepping, as the motors may take completely different positions when first turned on.
June 16, 2014 07:31PM
Could you put up the speaker build up link? I would love to see how those turned out, are you on DIYaudio.com?
WWW.ZATOPA.COM - Your Place for high quality 3D Printing Filament and accessories
A2
June 16, 2014 08:04PM
garyhlucas
I was just reading about this today. 3d routers that only use a master, and a slave stepper motor do shift a little, and it shows up as a stepped cut. A timing belt connecting two lead screws with one stepper motor fixes any shifting errors for the most part. I'm presently trying to figure out how to use 2 motors, master/slave, and a timing belt between parallel axis to work in harmony, (some thing needs to slip during tuning).
jzatopa
That's all there is, pretty cool though.
So is it possible to programmatically square up the build envelope?
June 17, 2014 04:39PM
I found the build log here
