Most Advanced Highest Performance Materials for FDM? July 07, 2014 12:11AM |
Re: Most Advanced Highest Performance Materials for FDM? July 07, 2014 01:25AM |
Re: Most Advanced Highest Performance Materials for FDM? July 08, 2014 06:35PM |
Re: Most Advanced Highest Performance Materials for FDM? July 08, 2014 06:58PM |
Re: Most Advanced Highest Performance Materials for FDM? July 12, 2014 12:05AM |
Re: Most Advanced Highest Performance Materials for FDM? July 12, 2014 08:25PM |
Re: Most Advanced Highest Performance Materials for FDM? October 20, 2014 01:49PM |
Re: Most Advanced Highest Performance Materials for FDM? December 15, 2014 01:34AM |
Re: Most Advanced Highest Performance Materials for FDM? December 16, 2014 11:18PM |
Re: Most Advanced Highest Performance Materials for FDM? December 17, 2014 09:12AM |
That's a pretty vague criteria when considering all types of thermoplastics. You really need to consider what the application is in order to figure out what the best performing material is. If you're making say a project box for some electronics, then impact resistance may be more important than temperature resistance. However if you need a cooling fan for around your hot end that's subject to 200+ degree temperatures, then a high temp plastic may be better suited then something with a low melting point. If you need resistance to particular chemicals, then that can change your selection as well.Quote
sanman
What are the most advanced or highest performing materials available for consumer-level FDM machines?
When I say "highest performing", I mostly mean mechanical or thermal properties...
