Multiple Heat Beds from 1 PSU
Posted by ayouden
July 07, 2014 06:39AM
Hey,
I currently have an experimental 3D Printer with a XY area of 400x400mm.
However, with it being un-heated I cannot use ABS.
For a project I need the print bed to be heated so I can use ABS.
For the size of the bed, I could use 4x 200x200mm RepRap MK2 heat beds.
Given if I use a large enough PSU, 30A+ and probably 24V would it be possible to run all 4x Heat beds in series or parallel to the PSU?
Has anyone hooked up multiple heat beds to a PSU before?
Thanks, Alex
NFireLabs - The World First Modular 3D Printer - At An Affordable Price!
Re: Multiple Heat Beds from 1 PSU
July 07, 2014 10:03AM
Yes, should work in parallel.
July 07, 2014 10:06AM
... given you have sufficient Solid State Relays or SevenSwitches connected to your RAMPS, of course. At such powers it might make sense to use a mains power (110V/220V) heating mat. They can be driven with an AC Solid State Relais in Bang-Bang mode.
July 07, 2014 11:09AM
Hey,
Thanks for the idea of using a mains powered heat mats with relays.
However, I cannot seem to find any mats!
Do you have an example?
Thanks, Alex
(And If I were to go down the 4x heat beds I would use a relay anyway to be on the safe side!)
Edited 1 time(s). Last edit at 07/07/2014 11:11AM by ayouden.
July 09, 2014 10:56AM
I would love more information on a heating mat. Can these be used to heat up a normal size bed faster? I am tired of waiting 20 min!
