Re: Has REPRAP come to a standstill? July 14, 2014 02:30PM |
WillAdams
'll keep at it, but I'd find it a lot easier if there were more alternatives for solder less connections --- my old soldering iron didn't show up in my Father's estate and I'm not that wild about using the mini torch he apparently replaced it w/ or getting a new one.
Re: Has REPRAP come to a standstill? July 14, 2014 04:23PM |
Traumflug
vegasloki
Shapeoko is a CNC router and while it cuts plastic it's not an additive process nor can it replicate many parts. There is an extensive Github, Wiki and active forum and user community.
Elsewhere, so no RepRap.
I struggle a bit with calling every cheap manufacturing machine a RepRap, just because the project owner happens to appear on IRC a few times. Or whatever makes people considering it a RepRap while cheap lathes and milling machines are not. And I'm perfectly fine with machines which are not part of RepRap. I own such stuff, too.
Re: Has REPRAP come to a standstill? July 14, 2014 04:44PM |
WillAdams
vegasloki
I agree that docs are one place where Reprap could be more comprehensive and consistent. That's a s much of a difference in the communities and the fact everyone here can have direct participation in the Wiki, as opposed to the benevolent dictator style used on the Shapeoko Wiki. ... When there is a free for all as is with Reprap the structure is disjointed and doesn't follow a standardized format and in some cases contains inaccurate information.
Who's being dicatorial on the Shapeoko wiki?
Aside from not tolerating linkspam, there's never been an edit or text addition which wasn't welcome.
The fact that things are so disjointed on the reprap wiki makes it all the more important that there be an overall structure to things --- a chronological listing at minimum would be easy and would provide some structure and make things a bit easier to find.
Here's an example of the github docs which I want fixed: [github.com] (should be ...wasteboard.pdf)
Re: Has REPRAP come to a standstill? July 14, 2014 10:03PM |
Re: Has REPRAP come to a standstill? July 14, 2014 10:29PM |
Re: Has REPRAP come to a standstill? July 15, 2014 07:01AM |
WillAdams
I've got quite enough to do, thank you.
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Has REPRAP come to a standstill? July 15, 2014 08:39AM |
Re: Has REPRAP come to a standstill? July 15, 2014 12:26PM |
Re: Has REPRAP come to a standstill? July 15, 2014 12:56PM |
Re: Has REPRAP come to a standstill? July 15, 2014 12:58PM |
Re: Has REPRAP come to a standstill? July 15, 2014 05:15PM |
MrDoctorDIV
Seriously though, it seems people here take things way too seriously sometimes. It often breaks out into personal attacks or look at me's. We've lost the community driven aspect and turned to making things better for ourselves. At least, that's how I've observed things.
Re: Has REPRAP come to a standstill? July 15, 2014 06:55PM |
Re: Has REPRAP come to a standstill? July 15, 2014 09:33PM |
Re: Has REPRAP come to a standstill? July 15, 2014 11:23PM |
pbrstreetgang
I agree 100% [forums.reprap.org]. What makes a product thrive is quality and cost. Not self replication. You can't make it ubiquitous and self replicating. The two concepts are mutually exclusive.
Basically, the concept of the reprap project should be minimalism, not self replication.
This list is an attempt to make a compromise between immediately-achievable technology and the desirable aim of shortening or eliminating it altogether. Note that it implies a machine that is capable of building three-dimensional objects from both an electrically insulating material and a conductor, like our deposition head in the picture. After the components have been made, it is quite acceptable for a person to assemble the machine from those components and the standard parts listed above, and to copy the firmware from the parent machine's microcontroller into that of the child.
The original idea of a Universal Constructor was of a machine that would both self-copy and self-assemble - as a bacterium or a daffodil do. The machine I propose will self-copy, but not self-assemble. In nature all four possibilities exist: things that neither self-copy nor self-assemble, like rocks; things that self-copy but don't self-assemble, like viruses; things that self-assemble but don't self-copy, like proteins; and finally things that both self-copy and self-assemble, like you and me. And you and I are quite dexterous at assembling machines that we want (even if we do swear at flat-pack furniture), so the second alternative (self-copying without self-assembly) is economically and practically the most interesting option. This web-page, therefore, is about making a useful virus that is as big as a fridge...
It would also be useful (though not initially essential) if the machine could grow itself by making appropriate components to extend its own movement axes, and could self-calibrate (possibly using an accurate reference object or a pattern of standard size) so that child machines would make products as accurately as their parent machine.
The three most important aspects of such a self-copying rapid-prototyping machine are that:
1. The number of them in existence and the wealth they produce can grow exponentially,
2. The machine becomes subject to evolution by artificial selection, and
3. The machine creates wealth with a minimal need for industrial manufacturing.
Re: Has REPRAP come to a standstill? July 16, 2014 12:16AM |
Re: Has REPRAP come to a standstill? July 16, 2014 01:20AM |
Re: Has REPRAP come to a standstill? July 16, 2014 02:10AM |
Re: Has REPRAP come to a standstill? July 16, 2014 07:20AM |
pbrstreetgang
Does it work, is it safe, is it affordable? That's it. Those 3 things.
Re: Has REPRAP come to a standstill? July 16, 2014 11:11AM |
Traumflug
By your measures you should build a WolfStrap. Still the cheapest design, safe, and it works.
Re: Has REPRAP come to a standstill? July 16, 2014 01:02PM |
pbrstreetgang
No more of Adrian Bowyer's pseudo-science. It's just white noise & soap operas as far as I'm concerned.
pbrstreetgang
Seriously, who cares if it's 3d printed or not.
Re: Has REPRAP come to a standstill? July 16, 2014 02:23PM |
Re: Has REPRAP come to a standstill? July 17, 2014 04:37AM |
smartfriendz
or buy a product ?
Re: Has REPRAP come to a standstill? July 17, 2014 04:49AM |
Feign
Personally, I think that dragging the capitalist/communist philosophy into the conversation is a huge mistake
Re: Has REPRAP come to a standstill? July 17, 2014 06:08AM |
Re: Has REPRAP come to a standstill? July 17, 2014 07:35AM |
Re: Has REPRAP come to a standstill? July 17, 2014 01:07PM |
