Full Graphic Smart Controller August 18, 2014 09:57AM |
Re: Full Graphic Smart Controller August 18, 2014 11:44AM |
Re: Full Graphic Smart Controller August 18, 2014 12:49PM |
Re: Full Graphic Smart Controller August 19, 2014 10:12AM |
Re: Full Graphic Smart Controller August 19, 2014 10:58AM |
Re: Full Graphic Smart Controller August 19, 2014 10:59AM |
Re: Full Graphic Smart Controller August 19, 2014 11:10AM |
Re: Full Graphic Smart Controller August 19, 2014 11:13AM |
tjb1
That bar is the indicator, it's based off file size I believe. There is currently no way to get a countdown timer or layer height. I have tried to get Kisslicer to add the total print time in seconds as a gcode which we could read in the firmware and countdown instead of up but it has not happened yet.
Avocation
Yes Jamesdanielv,
It's printing from the SD card.
The bar doesn't give a sense of time to complete though. Is there any way to achieve this at all?
Thanks far all the comments.
Richard
Re: Full Graphic Smart Controller August 19, 2014 12:18PM |
Re: Full Graphic Smart Controller August 19, 2014 12:40PM |
Avocation
Thanks TJB1,
What's the rationale for not adding this functionality? Surely it's valuable for lots of applications...
Richard
Re: Full Graphic Smart Controller August 19, 2014 08:14PM |
tjb1
Another problem is that displays like the full graphic do not work with delta printers on Marlin at least, running the display causes the printer to stutter through moves and pause at random times. The printer will work with it on but may have problems, I have tried it on mine with delta segments from 20-200 and can not resolve the problem without removing the display.
Re: Full Graphic Smart Controller August 20, 2014 07:30AM |
vreihen
tjb1
Try Repetier firmware. The full-graphics LCD (GLCD) support is supposedly better optimized versus Marlin, and my old Delta had very few and minor stutters with the GLCD enabled and no other firmware parameters changed.....
Re: Full Graphic Smart Controller June 29, 2015 09:46PM |
Re: Full Graphic Smart Controller June 30, 2015 04:20AM |
