Crazy Extruder Nozzle Idea
Posted by jupdyke
Re: Crazy Extruder Nozzle Idea
February 09, 2011 03:05AM
this is good and heavy machinable.I think using machinable glass mostly plays against the advantages using glass...
February 09, 2011 09:05PM
I just started looking into this reprap stuff so I may be out to lunch here. Would a hypodermic needle work for this? I checked here :
[en.wikipedia.org]
It looks like there are several id's one could work with. I would expect most people could get access to these locally too. If the length is too long you could probably cut them somehow.
February 09, 2011 10:05PM
They need to be all metal, and the narrow end needs to be very short, ~1mm. Otherwise the pressure needed to extrude gets very high. It is possible that they could work though.
VDX
February 10, 2011 03:22AM
... look here, at the last side - you can grind/shorten the tubes and through the luer-lock thread the fixing is really stable ...
Viktor
