Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:19AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:27AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:29AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:33AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:34AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:37AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:42AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:46AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:49AM |
/* -*- c++ -*- */ /* Reprap firmware based on Sprinter and grbl. Copyright (C) 2011 Camiel Gubbels / Erik van der Zalm This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version. This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details. You should have received a copy of the GNU General Public License along with this program. If not, see [www.gnu.org]. */ /* This firmware is a mashup between Sprinter and grbl. (https://github.com/kliment/Sprinter) (https://github.com/simen/grbl/tree) It has preliminary support for Matthew Roberts advance algorithm [reprap.org] */ /* All the implementation is done in *.cpp files to get better compatibility with avr-gcc without the Arduino IDE */ /* Use this file to help the Arduino IDE find which Arduino libraries are needed and to keep documentation on GCode */ #include "Configuration.h" #include "pins.h" #ifdef ULTRA_LCD #if defined(LCD_I2C_TYPE_PCF8575) #include #include #elif defined(LCD_I2C_TYPE_MCP23017) || defined(LCD_I2C_TYPE_MCP23008) #include #include #elif defined(DOGLCD) #include // library for graphics LCD by Oli Kraus (https://code.google.com/p/u8glib/) #else #include // library for character LCD #endif #endif #if defined(DIGIPOTSS_PIN) && DIGIPOTSS_PIN > -1 #include #endif #if defined(DIGIPOT_I2C) #include #endif
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 08:59AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:06AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:17AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:26AM |
#if MOTHERBOARD == 88 #define KNOWN_BOARD 1 #define AT90USB 1286 // Disable MarlinSerial etc. #ifndef __AVR_AT90USB1286__ #error Oops! Make sure you have 'Teensy++ 2.0' selected from the 'Tools -> Boards' menu. #endif
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:31AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:34AM |
* Arduino Mega pin assignment
#if MOTHERBOARD == 3 || MOTHERBOARD == 33 || MOTHERBOARD == 34 || MOTHERBOARD == 35 || MOTHERBOARD == 77 || MOTHERBOARD == 67 || MOTHERBOARD == 68
#define KNOWN_BOARD 33
//////////////////FIX THIS//////////////
//#ifndef __AVR_ATmega1280__
#ifndef __AVR_ATmega2560__
#error Oops! Make sure you have 'Arduino Mega' selected from the 'Tools -> Boards' menu.
#endif
#endif
// uncomment one of the following lines for RAMPS v1.3 or v1.0, comment both for v1.2 or 1.1
#define RAMPS_V_1_3
// #define RAMPS_V_1_0
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:37AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:38AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:43AM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:49AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 09:58AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 10:18AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 10:26AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 11:17AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 11:22AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 11:26AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 11:39AM |
Re: Need Help with first RepRap configuration (Prusa I3 Rework) August 27, 2014 12:10PM |
