x and y axis work, but z axis makes the motors buzz and stick
September 07, 2014 12:33PM
I have a RAMPS 1.4 board that I installed the newest Marlin firmware on. I have the printer (Prusa i3) mostly assembled, except I disconnected z-threaded rods and need end stops.
Controlling with the smart LCD controller, I can move X, Y without problems. However when I move the z axis the motors buzz/hum and try to rotate, but can't. This seems to be to be a problem with the amps so I dialed the potmeter but there is not 'stop' so I don't know when it is turned up or down. As even at full amps the motors should burn, I don't think the stepper board is the problem.
So I was wondering if this could somehow be the firmware preventing the z from spinning? Or if it could be broken electronics.
Thanks in advance.
- Nic
Re: x and y axis work, but z axis makes the motors buzz and stick
September 07, 2014 01:28PM
is it a high pitch hum, and what feedrate are you trying to move it at?
my guess it that z axis speed is set higher than it should be or your speed in mm/s and mm/m are off. try 180mm/m or 3mm/s on z axis. you can also change the max feedrate in firmware.
November 27, 2014 08:50PM
I'm having the same issue.
I'm also not sure that + and - are going where they're supposed to. I can reverse the direction in the Marlin firmware, correct?
November 29, 2014 12:32AM
try slightly backing out the screw on the z axis stepper driver. the problem might be that theres not enough current going to the z motors. I had the same problem.
December 01, 2014 07:27AM
I often see this problem on IRC, and I tell people to adjust their Z feedrate, then it will works. In your configuration.h (Marlin), set the Z HOMING_FEEDRATE and Z DEFAULT_MAX_FEEDRATE to 2 or 3.
If it doesn't help, maybe it is a wiring error?
