The bolt pattern is different, hence the need to change the mount or extruder. You also do not want gears on the extruder if you have them in the stepper motor, hence a whole new extruder.
If you want to use it with a bowden, no problem. If you want it directly on the delta effector, bad idea. It's bad enough using a small PG35L on it, and that weighs 1/3rd or less of a geared stepper motor. They are surprisingly quite heavy and your steppers may lack the torque to move the head.
