bend heat bed
Posted by sungod3k
bend heat bed
September 18, 2014 05:01PM
hey,
I just received my first standard mk2 heat bed. before i used a custom capton sticker not a rigid surface like the MK2. However its visibly quite bend.
my question is if that matters if the glass or mirror is laying on there. I saw these clippers here http://thingiverse-production.s3.amazonaws.com/renders/b7/ec/60/ca/a9/IMG-20130823-WA0010_preview_featured.jpg which would force the bed onto the glass, or shouldnt i bother and return it right away?
Cheers
Re: bend heat bed
September 18, 2014 08:57PM
I have just been making my own heated beds using resistors
yours does look bent, is the top glass perfectly flat still?
Does it heat the whole piece of glass up?
Re: bend heat bed
September 19, 2014 03:09AM
I only bought the bed not the glass.
Re: bend heat bed
September 19, 2014 06:16AM
It looks like you are trying to print on the heater.
You need a bed on top of the heater to flatten the surface.
I have 20cm mirror tiles from ikea and use 8 clips to fix it to the heater.
2 on each side.
This levels it out and gives you a good surface to put your tape or whatever you are using to make the print stick.
Instead of bulldog clips im using the larger supaclips that you put on paper with a little tool.
Much lower profile and less likely to hit the nozzle.
Keeps dveryghing secure.
Gordon
Re: bend heat bed
September 19, 2014 06:30AM
I wont print directly on the bed smiling smiley
ok clips it is. thanks
Re: bend heat bed
September 19, 2014 06:34AM
good luck !!!! have fun
