bootloader 1284p
Posted by farias
bootloader 1284p
September 29, 2014 12:18PM
please anyone knows how to load the bootloader atmega 1284p using a 16 MHz ceramic resonator need to do some configuration in JTAG fuse ?? because the new firmware and marlin has disabled the JTAG but for 20 MHz crystal or ceramic ???
thanks for your prompt response.
Re: bootloader 1284p
September 30, 2014 06:56AM
Arduinos and RepRap controllers generally don't use JTAG. On how to upload bootloaders: [reprap.org] A fuse calculator to find out how to change fuses to enable JTAG: [www.engbedded.com] From there on you likely have to resort to Atmel documentation on how to make use of this JTAG.
Hint: Teacup developers use a cycle-accurate simulator instead. Much easier, as you can pause the CPU clock and also investigate many I/O pins at the same time: [reprap.org] Similarly powerful hardware equipments exist, but they're quite costly and complicated. The only thing not working in the simulator is double-speed serial (would require a fix in SimulAVR), so you're limited to about 38400 baud. Not really a limitation for debugging.
September 30, 2014 09:40PM
thanks a lot! this information is new for me.
