Why did my PLA print start warping in middle of the print
September 30, 2014 10:04AM
The prints did not come off the table, the layer above it just started warping, hows that possible?
please look at the pictures
what should i do?
[postimg.org]
[postimg.org]
Re: Why did my PLA print start warping in middle of the print
September 30, 2014 11:39AM
Bad layer adhesion? If the top starts warping before the bottom comes off, sounds like your layers aren't anchored together well enough.
October 01, 2014 02:53AM
My bet would be insufficient cooling of the print. Can't really tell from the pics, but poor cooling leads to the top of the print curling/not setting properly, which will mess up more the further the print goes.
October 01, 2014 03:33AM
What temp, filament size and layer height? Did you get a close up of the layer that failed? Heated bed?
October 01, 2014 11:19AM
from what i see, this is my opinion as of today
flow is not consistent. how much cooling does your pla get from cold end? for example is a fan pointed directly at cold end, before pla enters the hot region. this could be gunking up as pla can soften like gummy candy and plug up and not move. how well does your extrude extrude pla, and what is your retraction setting?
bottom line pla does not warp that much , it gets underfeed thru the extruder, and in your case it is not warping, it is adhesion.
why does a layer not stick to previous layers? 1 layer height is not calibrated, flow is not consistent, meaning some layers are likely missing.
so what do i think? i think that flow is not consistent and this is causing perimeters to not be laid down to where there is adhesion to previous layer (because it is not there!)
what to i suggest: slow down infill speed by half, and then if issue still, slow down entire print. fast is only OK if your machine does not wast feed stock.
try only 1 print object at a time for short term
others here have different experiences and one of several people will likely help you out!
Edited 1 time(s). Last edit at 10/01/2014 11:21AM by jamesdanielv.
October 01, 2014 02:39PM
I've seen that sort of thing happen if a belt slips - it starts printing in midair and everything gets dragged all over the place.
