Acme LeadScrews October 10, 2014 09:25PM |
Re: Acme LeadScrews October 11, 2014 10:56AM |
Re: Acme LeadScrews October 11, 2014 11:21AM |
That is what I thought it was long ago. Then I did a simple test with a cube. One i printed at .2, the other i printed at .197 something that was calculated, and the other calculation around .21.... And they turned out the exact same. The tops of my threaded rods move at least 1.5 cm while it rotates so I thought this was a major problem. [www.robotdigg.com] This is the lead screw I was planning on buying. One thing I am concerned is that my smooth rods are 8mm too, I remember people saying you want the threaded rods to be thinner? So that they don't counter the path of the smooth rod. Should this be a concern?Quote
stonedcoldskier
They should work very well for your Z-axis. Where are you planning to get the anti-backlash nuts? I haven't seen any at a reasonable price. For what it's worth, there are other causes of banding. The biggest problem that I have seen is selecting the wrong layer height which results in fractional numbers of steps for z moves. The motors will settle at the closest full step and that can result in a "fat layer, skinny layer, fat layer, etc." pattern throughout the print. Refer to the prusa calculator to see if you're using an optimal layer height first. If not, try running a few prints with a recommended layer height. I think you may be surprised by the results even if you see obvious wobbles in your z-axis lifting rods.
Re: Acme LeadScrews October 11, 2014 01:25PM |
