:: windows GCODE viewers ?? recommend ??
Posted by redreprap
October 15, 2014 11:39PM
hello folks ...
ive been MIA for some time ...
recently managed to re-setup the PC to do some gcode stuff. and i tried to re-use pcb-gcode.
i tried to view the gcode in a GCODEsimulator.jar ... it doesnt read
any idea what could be a good way to view this virtually to know whats the code doing?
thanks
Edited 1 time(s). Last edit at 10/15/2014 11:51PM by redreprap.
______________________________________
__my mixed bag blog || aka --> [http] || ___ so 3D printing is everywhere ... dont worry, hospitals can now 3Dprint body parts, they will charge you $1million excluding surgical fees ... you will die paying your debts. thats their aim ___ if every patent expires tomorrow, everybody will surely get a 3dprinter and make EVERYTHING ! ____ there is a "DIY-DTG" t shirt printing forum, you can mod an EPSON printer to PRINT like a pro. ___ CNCzone? overly commercialized it seems ___ my country? they will be taxing you for every cm of road you use and track you to your grave using GPS and its government authorized, now they will fire all the traffic wardens instead.___ EEVBLOG? there is only 1 way to do things --> take it apart like a pro
open | download - PWMmotor2014b.bot.etch.tap (138.5 KB)
Re: :: windows GCODE viewers ?? recommend ??
October 16, 2014 12:07AM
You could load the g-code into a 3d printer host like Repetier host.
You could.view the path and such.
October 16, 2014 02:05AM
pushthatbolder
thanks for that, nice program ... (waiting for mroe time to try)
i downloaded a STL file (40mm test cube)
this is what it looks like in notepad
Binary STL output from Blender: C:\Documents and Settings\raphael\Desktop\40mmcu ûÿŸAúÿŸA ûÿŸAûÿŸÁ üÿŸÁùÿŸÁ ûÿŸAúÿŸA üÿŸÁùÿŸÁ ÷ÿŸÁÿÿŸA  AõÿŸA BúÿŸÁûÿŸA BÿÿŸÁ÷ÿŸÁ B  AõÿŸA BÿÿŸÁ÷ÿŸÁ BôÿŸA  Á B ûÿŸAúÿŸA  AõÿŸA BôÿŸA  Á B ûÿŸAúÿŸA ôÿŸA  Á BûÿŸAûÿŸÁ ûÿŸAûÿŸÁ ôÿŸA  Á BÿÿŸÁ÷ÿŸÁ B ûÿŸAûÿŸÁ ÿÿŸÁ÷ÿŸÁ BüÿŸÁùÿŸÁ üÿŸÁùÿŸÁ ÿÿŸÁ÷ÿŸÁ BúÿŸÁûÿŸA B üÿŸÁùÿŸÁ úÿŸÁûÿŸA B÷ÿŸÁÿÿŸA  AõÿŸA BûÿŸAúÿŸA ÷ÿŸÁÿÿŸA  AõÿŸA B÷ÿŸÁÿÿŸA úÿŸÁûÿŸA B
so what do i use to STL --> gcode? if i would like to see the actual G-commands in text file ?
open | download - 40mmcube.stl (684 bytes)
October 16, 2014 03:08PM
To do the STL-->gcode, use the Repetier host. Look under slicer and select either Slic3r or, in the latest versions, Cura as the slicer, play with the configuration and slice.
To look at the STL: use Netfabb Basic to import the part in STL and then export as STL (ASCII). Your flie looks like:-
solid 40mmcube
facet normal 0.000000 0.000000 -1.000000
outer loop
vertex 19.999990 19.999989 0.000000
vertex 19.999990 -19.999990 0.000000
vertex -19.999992 -19.999987 0.000000
endloop
endfacet
outer loop
vertex -19.999983 19.999998 0.000000
endloop
endfacet
With some more facets similar to the above.
Mike
October 16, 2014 09:40PM
Ok. You have designed a cube?
1st. Save as stl.
2nd open in Repetier host.
3rd Realise error, object not manifold or similar.
4th find Nettfab (google it)
5th fix with it and download fixed stl
6th load fixed stl into repetier host
From repetier host. After your printer and slic3r setting configuration.You slice your stl. And
then it gives you a preview and an option to view the gcode.
It has the option to save to sd card. Etc.
Host programs are cool. They are drag and drop.
Download from Web, then drag in...
Probably want to start with 10mm cube.
Just in case it goes bad. And with 10mm cube. ¥ou will $ave your fi£am€nt
Edited 1 time(s). Last edit at 10/16/2014 09:48PM by pushthatbolder.
