ULTEM 9085 October 23, 2014 12:24PM |
Re: ULTEM 9085 October 23, 2014 03:32PM |
Re: ULTEM 9085 October 23, 2014 05:21PM |
Admin Registered: 11 years ago Posts: 3,096 |
Andrew Smith
Injection molders use a nozzle temp of 330-350C, which gives you a starting point for experimentation. So you're going to need an all-metal hot end with a thermocouple. The MSDS suggests it decomposes above 300C and that the fumes may be pretty toxic, so an enclosed machine and filtered exhaust are recommended. Also, you probably need to heat the chamber to close to the glass transition point which is 186C. The stratasys machines that print this stuff have been described as having an oven for a print chamber.
Also, I have no idea where to get it in filament form, and it costs a fortune even in sheet or rod form.
Re: ULTEM 9085 October 27, 2014 12:58PM |
Re: ULTEM 9085 October 27, 2014 01:35PM |
